help on electrical
Old Jul 27, 2002 | 10:17 PM
kbk212's Avatar
kbk212
Cruising
Default help on electrical
my alt puts out 12 volts untill i rev it up and then goes up to 27 volts and blows fuses any ideals or help thanks
Old Jul 27, 2002 | 10:31 PM
daily_driver's Avatar
daily_driver
Default Re: help on electrical (kbk212)
sounds like your voltage regulator aint regulating..
swap out the alt.
Old Jul 27, 2002 | 10:39 PM
kbk212's Avatar
kbk212
Cruising
Default Re: help on electrical (daily_driver)
thanks for the fast reply but i did that first then again
i changed over to digital gauges and afraid to put them into car
Old Jul 28, 2002 | 12:10 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
So, you have changed out the alternator and have the exact same problem?
If so, look for a loose ground connection.
Old Jul 28, 2002 | 01:08 AM
rollavette71's Avatar
rollavette71
27 volts! That's a lot! Are you sure that reading is correct? I've run a couple of altenators
with NO voltage regulator in the circuit and the most I've ever gotten is around 16-17 volts.
I can't imagine how one could get 27 volts.
Old Jul 28, 2002 | 11:10 AM
kbk212's Avatar
kbk212
Cruising
Default Re: help on electrical (rollavette71)
yes the readings correct i could not understand it either but its accurate :confused:
Old Jul 28, 2002 | 11:13 AM
kbk212's Avatar
kbk212
Cruising
Default Re: help on electrical (71,454,4spd)
ill try that next thanks
To help on electrical
