progress being made at the dragstrip
After several aborted trips to the dragstrip including one pass where the engine apparently died halfway down the track, my initial objective was just to make a clean pass!
May 25 - (Just trying to get thru the 1/4 mile:
15.099 @ 94.36 mph
phew! so I push it a little harder, and get:
14.795 @94.99 mph
Next, my pertronix conveniently fails, so I get part #s from lars and go back to points. I also install a set of light springs in the distributor and use the lars method to set the timing at 36 degs all-in pretty quick (because of the lighter springs.... somewhere around 2300-2500 rpm)
June 29 - It is really HOT! (around 95 degrees I think), and I am idling for quite some time in line. Engine temp reads above 210 - not OVERheating, but kind of hot.
14.434 @ 96.79 mph. I am thinking that I am getting better at driving, but then realize the tuning must have added some real power. I am pretty psyched up, but on the next run the old fuel delivery issue seems to come up again, engine dies out, and I call it a day and go home.
So, I change my oil (still using dino) but change the trans oil to Mobil 1, but the truth is I probably only suck out half the old oil, which isnt old anyway.
AND (big AND), I move my vacuum advance line from the front of my carb to the side of my carb. I was getting no vacuum advance at idle in the old location, but I do in the new location. This seems to help the car run cooler at idle. Which brings us to today:
This really shocked me! :eek:
14.485 @ 100.28 mph
Air temp was a lot cooler today, plus I was at the front of the line so didnt have to idle a lot. When I started my pass, engine temp was, maybe 180.
Next run the engine temp was a bit higher, maybe 200.
14.367 @ 99.27 mph So, new best et but slightly slower mph. I really think it was the engine temp, but I wonder if the vacuum advance really made a difference. There is an easy way to find out.... next time! :)
MJ
[Modified by MNJack, 10:50 PM 7/27/2002]
Nice job on the times. It looks like you're perfecting your driving!
-Joe
Great to see you again!
Joe.... where were ya? Aside from a little rain delay you missed a great day at the track! :smash: :cheers: :cheers:
:cheers:
Olivier
Sorry I missed you!
:cheers:
Olivier
btw, someday i will get you to go into the elims :p:
see you at the next one?
keep up the good work.
I'm sure you'll see 13 soon... He you can race mine if I can race yours!!! :cheers: :D
