Changing Valve Springs
Old Aug 26, 2014 | 01:09 PM
brian76's Avatar
brian76
Default Changing Valve Springs
I was going to adjust the valves on my 383 and realized that there were single springs on the motor. Found a box in the garage and it had 16 smaller springs in it. I broke the cam in with the single springs and forgot to install the inner springs! Engine has about 100 hrs. on it since new. My question is- how do I install the inner springs? It's obvious that I have to remove the retainers to do it but how hard of a job is it with the heads on the car? I don't want to remove them. Do I buy some hose that will screw into the spark plug hole and pressurize it with a compressor? Do I have to use one of those crowbar tools on the rocker stud to compress the spring? Has anybody ever done this, and how hard was it? Thanx
Old Aug 26, 2014 | 01:43 PM
lars's Avatar
lars
It's quick and easy to do. Just buy a valve spring compressor like this:
http://www.summitracing.com/parts/sum-906784/overview/
and buy a cylinder pressurization hose like this:
http://www.summitracing.com/parts/wmr-w84003/overview/
Put a little pressure in the cylinder (the engine will rotate to BDC when you do, so watch that fan blade..!) and pop the retainers off, one at a time. You can do the entire job in less than an hour, even with a couple of beers.
Lars
Old Aug 26, 2014 | 03:28 PM
Ironcross's Avatar
Ironcross
Lars
...........all that's missing is the beer.........
Old Aug 26, 2014 | 04:05 PM
tonak's Avatar
tonak
Lars
Took me a lot longer even with the same spring compressor. Guess I needed the beers!
Old Aug 26, 2014 | 07:02 PM
brian76's Avatar
brian76
Okay, went to Jegs and got the parts. Beers are on order and will do it when they arrive
Old Aug 26, 2014 | 07:15 PM
redvetracr's Avatar
redvetracr
have a magnet handy, oily fingers and "keepers" don`t mix.
Old Aug 26, 2014 | 07:20 PM
hugie82's Avatar
hugie82
Make sure you bring the piston up on the cylinder you're working on. If you drop a valve, you'll be pulling a head but if your motor is running fine at high rpm, I would leave it. You're just increasing the potential of wiping a cam lobe with more pressure. IMO
Old Aug 27, 2014 | 10:18 AM
lars's Avatar
lars
That won't work with the air pressure system. Once you remove the rocker arms, the valves will be closed. When pressure is applied, the air will force the piston down to bottom dead center. If you have it at the top of the stroke, the engine simply rotates 180 degrees in a real hurry... keep fingers and hands clear...
Another tip: Often, the keeper/retainer system will be a little "sticky", and will not break loose when you pull the valve spring compressor over. If this happens, you'll open the valve and loose air pressure. If you feel that the retainer is not going to break loose, give it a few taps with a rubber mallet as you pull on the compressor handle. This will knock it loose to prevent the valve from opening.
Lars
Old Aug 27, 2014 | 12:03 PM
hugie82's Avatar
hugie82
Lars
I don't know how much pressure you pump into the spark plug hole but I've never had a problem with 30psi and the engine at TDC. I agree if it's half way down in the bore it might spin on you.
Accidentally break that pressure seal or pop an air line and you just added 4 hours of labor. But hey, everyone has their thing but don't knock them for it
Old Aug 27, 2014 | 10:58 PM
lars's Avatar
lars
If you're putting 30 psi in a 4-inch bore 350 (that's 30 psi applied over an area of 12.56 square inches), you're putting 377 pounds of force on top of your piston. If your engine doesn't spin over with 377 pounds of force on the piston, whether it's at TDC or not, you have a problem... I've been doing this for 40 years, and I've never even heard of someone dropping a valve using the method. (I run 20 psi when doing this, and that 20 psi will spin a TDC piston over very quickly, so I keep hands and fingers clear. I pull all 8 spark plugs out when doing this, so maybe you're temporarily locked against compression pressure. I don't trust compression pressure on a companion cylinder as an anti-rotation device.)
Lars
To Changing Valve Springs
