Pedal assembly setup
Old Aug 26, 2014 | 10:39 PM
NothingSpecial's Avatar
NothingSpecial
Default Pedal assembly setup
Did the manual to power conversion on my 75. Wondering what the proper way to set up the brake pedal is?
It looks like if I let the pedal hit the rubber bumper, I cant get it to connect with the booster clevis.
Did manuals have different rubber bumpers than the power? Or do they not connect normally.
Old Aug 27, 2014 | 02:31 AM
76CSRvette's Avatar
76CSRvette
have you checked willcox site in repair section. they have a lot of helpful pics
Old Aug 27, 2014 | 06:02 AM
SH-60B's Avatar
SH-60B
I did an automatic with power brakes to manual transmission swap, pretty sure the pedals for a standard work with manual brakes. With each pedal assemble side by side only the brake pedal is different. The power brake clevis was short so I had to lengthen it to mate with the pedal arm. The brakes actually work better than ever now.
Old Aug 29, 2014 | 10:14 AM
NothingSpecial
Checked wilcox, Never knew they had so many tech articles, thanks! Didn't have what I needed for this part of the project.
Hmm. My pedal arm goes down by about two inches when I install the booster; leaving the pedal about a half inch above the gas. It doesn't hit the rubber bushing. Judging from the condition of it, I'm not sure it ever did hit it.
I checked my pop's 68, his seems to be the same height. Clutch pedal is about two inches above.
I have the pedal low enough that it doesn't cause leg cramps now.
Thanks for the help!
Old Sep 25, 2014 | 11:24 PM
Richard454's Avatar
Richard454
Here what I have found-
Manual (un-restored) Power (restored)
If you notice the rod assembly is using the TOP hole on the pedal- where as the Power uses the lower hole- Brake switch piece is longer for the Power and shorter for the manual...
Is this the common consensus? I have heard a lot of info re the clevis pin/ style and rod length- but not this-
DSCN4770 by richardhayes454, on Flickr
DSCN4771 by richardhayes454, on Flickr
DSCN4772 by richardhayes454, on Flickr
To Pedal assembly setup
