First timer when it comes to timing. 72 350 with HEI distributor.
I changed plug, wires, cap and rotor. Reinstalled cap and rotor same way they came off. All plug wires installed correctly. Vacuum advance disconnected and plugged. Have the black springs from Mr. Gasket kit installed on distributor. Using a digital dial back timing light I can't even get the initial or or total timing even close. When I turn the distributor clockwise to get the timing mark to come back towards the tab the idle goes way low and tries to die. Can't even see the timing mark when trying to get 36* at 2500 rpm. What am I doing wrong? Any help would be appreciated.
another trick to help seeing the line on the harmonic damper is to take some white paint/nail polish and paint the line. When setting the total timing for 36 degrees remove one of the black springs and then reinstall when set.
White paint did the trick. Can see it clearly now. Thanks to all for the help.
If I am getting 36* all in at 2700 RPM with gold springs installed do I still need to put the original springs (which were the black ones) back in after I get it set?
You can also adjust the idle screw "in" another 1/4 to 1/2 turn so the engine will not stall while you are trying to set the timing.
Try timing the engine "by ear" at first........start the car/slowly rotate the distributor until the engine is running smoothly/slowly turn the distributor until the engine rpm slows----mark that spot on the distributor base and intake manifold with a dab of white-out or white paint/then slowly rotate the distributor in the other direction until the engine idles fast----mark that spot on the distributor base with a different color paint/then slowly turn the distributor halfway between the two different-color marks and snug it down with the hold down clamp so it won't rotate by itself.
Then use your timing light as the other members suggested to see if the harmonic balance is even close to the timing tab .........re-adjust the distributor with the timing light to the correct degrees.
(you can paint a straight line across the face of the harmonic balance----after driving the car a few times, the painted line should remain straight--if the outer balance ring is loose, the painted line will begin to appear crooked/broken).
