I'm in the process of swapping a 94 lt1 into an 80 and wanted to know cam options.
For now I'm going to keep everything stock on the motor (except for 1.6rr and MSD box and 26# injectors for the cam, long tube headers) and leave the 3:08 inplace. Have a 700r4 with shiftkit 1800 stall.
I had the HOTCAM kit on another build but want more lobe - I don't want to add in a vacuum can.would like to use the gm846 cam(with matching springs) and not have to use a vacuum can? Or does anyone have any thoughts
Got it confused for the 847 which is somewhat nastier
You could probably get away with it for awhile with some converter
Pushing limits with a stock converter
Not sure youd even need a vac reservoir
