69 Lower Dash Passenger Side Removal
Old Aug 29, 2014 | 02:44 PM
afnoce's Avatar
afnoce
Default 69 Lower Dash Passenger Side Removal
I'd like to replace my tired old map pocket with a brand new one I just purchased. I know that I need to remove the passenger side lower dash in order to do so. I've removed the two screws closest to door jam, the three along the top closest to the upper dash and the two on side closest to the instrument cluster. Also remove the vent **** as well. As I try to pry the lower dash off...it seems to be stuck on the upper left side closest to the instrument gages. I don't want to force it and risk breaking 44 year old plastic or anything else behind. Any suggestions?
Old Aug 29, 2014 | 03:24 PM
TX-Techman's Avatar
TX-Techman
The link below is about dash pad removal but covers removing the passenger side lower dash panel as well. I believe there is another fastener behind the map pocket on a 69. I did mine in 2008 so do not remember all the detail. there is also a link to the Wilcox tech note on removing the dash pad.
Old Aug 29, 2014 | 03:36 PM
blitz10's Avatar
blitz10
I need to do the same on my 69. New map pocket had been installed but it is stretched out more than the old one. Had mechanic do it while replacing the heater core.
To 69 Lower Dash Passenger Side Removal
