Suddenly have no power steering
Old Aug 31, 2014 | 02:32 PM
AirborneSilva's Avatar
AirborneSilva
Default Suddenly have no power steering
I recently changed both my power steering pump and power steering control valve, it worked great for the past week or so. Then this morning after warming the car up I was pulling out of the driveway and the steering felt pretty stiff, then I noticed at a stop it was very difficult to turn the wheel. I stopped to check the belt, tight, so I checked the fluid level, right in the middle of full and add. No leaks - so, what are my options? As usual, thanks for looking and any help you can give.
Old Aug 31, 2014 | 03:54 PM
DUB's Avatar
DUB
I would suspect the power steering pump myself.
DUB
Old Aug 31, 2014 | 04:03 PM
AirborneSilva
DUB
Thanks DUB, figures, the damn thing is only about a month old and its the second in less than 6 weeks, the one prior started to leak in less than a week now this one seems to be dead
Old Aug 31, 2014 | 06:14 PM
mrvette's Avatar
mrvette
Fill it up, turn the steering R-L full tilt, until it goes EEEEE and then fill it again, let it set overnight.....
then see what happens.....
Old Aug 31, 2014 | 07:07 PM
DUB's Avatar
DUB
You should actually see a bit of movement in the p/s fluid when the engine is running and the cap is off....if you are lucky so be able to see down into the reservoir.
DUB
Old Aug 31, 2014 | 08:11 PM
AirborneSilva
It has fluid in it...
Old Aug 31, 2014 | 08:12 PM
AirborneSilva
DUB
Thanks, I'll take a look to see what I can see.
Old Aug 31, 2014 | 09:04 PM
AirborneSilva
I think you nailed it DUB, I did put in a little more fluid just to bring it up close to the top, started it up - no movement
DAMN!!! Well I hope the third is the charm
Old Sep 1, 2014 | 08:06 AM
Jim Shea's Avatar
Jim Shea
Recently there was a posting where a new PS pump had a stuck flow control valve. If that valve (which is located inside the pump) sticks you will not have any power assist.
Remove the power steering hose assembly, now you will be able to unscrew the pump discharge fitting. Behind the fitting will be a slider valve and then a spring. You should be able to take a long probe and push on the valve. It should easily slide back and forth in the pump housing valve bore against the spring. If it sticks you have found the source of your problem.
Old Sep 1, 2014 | 09:21 AM
AirborneSilva
Thank you Jim
Old Sep 1, 2014 | 09:43 AM
AirborneSilva
One Question Jim, can this be done with it attached to the motor or do I have to pull it
Old Sep 1, 2014 | 05:14 PM
DUB's Avatar
DUB
It can be done with the pump on the engine. Or at least should be.
DUB
Old Sep 1, 2014 | 05:44 PM
AirborneSilva
DUB
Thanks DUB, guess I'll crawl under it tomorrow after work, been a lazy bastard all day today
Old Sep 2, 2014 | 09:04 AM
AirborneSilva
Jim, just so I'm clear on what I should do, in the picture below (taken from one of your papers - thank you), after taking off the power steering hose from the back I unscrew the #24 in the pic below to test if the valve is sticking or not?
Thank you for your help and time! Tony
Old Sep 2, 2014 | 06:08 PM
DUB's Avatar
DUB
Originally Posted by airbornesilva
jim, just so i'm clear on what i should do, in the picture below (taken from one of your papers - thank you), after taking off the power steering hose from the back i unscrew the #24 in the pic below to test if the valve is sticking or not?
thank you for your help and time! Tony
correct!
Dub
Old Sep 2, 2014 | 06:42 PM
AirborneSilva
Thanks Dub, I did pull that out but didn't find any spring. I probed around in there with a phillips screw driver but couldn't get anything to move so I put it all back together, filled with oil and it worked. It fills stiffer so I don't have high hopes that it's going to last but at least I am confident that it is the pump.
To Suddenly have no power steering
