Pic request
Old Sep 6, 2014 | 04:43 PM
Vette-kid's Avatar
Vette-kid
Default Pic request
Im having a hard time getting my AC brackets to line up. Car is a 78 L48. Can anyone get me good pics of the mounting brackets with the compressor installed (R4)? Im having a hard time seeing what I need on the AM. Brackets look right, but the compressor is about an inch away from the adjuster bracket.
Alternative, does anyone know of a good aftermarket bracket for R4 compressors?
Old Sep 6, 2014 | 07:07 PM
7t9l82's Avatar
7t9l82
do you have aftermarket heads?
Old Sep 6, 2014 | 08:11 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Don't know if this will help, compressor's not in place.....
https://www.corvetteforum.com/forums...-mounting.html
Old Sep 6, 2014 | 09:59 PM
Vette-kid's Avatar
Vette-kid
Yes, but the holes should be the same right? The bolts line up fine on the lower part of the bracket (water pump bolt and the shared bolt on the head). Its a complete after market motor, nothing original about it.
Old Sep 6, 2014 | 10:02 PM
7t9l82's Avatar
7t9l82
I've seen some heads that the holes are in the right place just they don't come as far out as factory you may have to make spacers. without seeing it kinda hard to say.
Old Sep 7, 2014 | 05:53 PM
Vette-kid's Avatar
Vette-kid
Sorta...I had the lower brace upside down, blocking the water hose. That shoulda been self explanatory
Id like to see the orientation of the compressor itself and how it looks installed. Front front and back if anyone has it.
Old Sep 7, 2014 | 05:57 PM
Vette-kid's Avatar
Vette-kid
Yeah, I think that may be the case. I found a spacer that's about 3/4" and that seems to work ok. Im not sure I have the compressor in the right orientation though. In order to get everything to line up I started with the front bolts and worked my way up and back. Now the hole that goes into the exhaust bolt isn't lining up. I may have to attack a few of the holes in the bracket with a dremel to give me some room.
I wouldn't mind an aftermarket bracket, but I cant seem to find one for an R4 compressor. Its pretty annoying actually...plenty of R4 brackets for LS engines though
Old Sep 7, 2014 | 05:58 PM
hugie82's Avatar
hugie82
If you still have the AC lines in place, hold them up to the compressor. They usually stay in the same shape over years of being in place. That will give you the original clocking of the compressor. The clutch plug is always on top or clocked toward the passenger side fender.
Old Sep 7, 2014 | 06:07 PM
Vette-kid's Avatar
Vette-kid
I wish that was an option...engine is out of the car. Has been for years. so the electrical plug aims up and toward pass side?
Old Sep 7, 2014 | 06:10 PM
hugie82's Avatar
hugie82
Google image L82 or L48 and it should give you a few views. That's what I usually do.... Good luck
To Pic request
