Timing
Old Sep 7, 2014 | 08:17 AM
charleyahrens's Avatar
charleyahrens
Default Timing
I have heard many different opinions on setting the initial timing.
I have a stock 81. What should the initial timing be set at?
Old Sep 7, 2014 | 08:50 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
My '81 with manual transmission is 6 degrees at 700RPM...Be sure to follow the shop manual instructions ( there are several steps to get the timing correct because of the computer controlled carb )...Good Luck!
Old Sep 7, 2014 | 10:55 AM
lars's Avatar
lars
There shouldn't be much "opinion" on setting timing an the '81 ECM-controlled car. Timing is set to 6 with the ECM wire to the distributor disconnected. Once completed, hook the wire back up. The ECM takes care of timing from that point on.
As a note, the ECM does not "know" where the initial timing has been set. It just assumes that it's working off a 6-degree baseline, and it advances timing from that point per the programmed advance profile. It will retard the timing if the knock sensor goes off. For higher altitude applications, you can gain a slight benefit from advancing the initial timing 2 degrees to about 8, and the ECM will then run the entire advance curve 2 degrees advanced. This is unlike the "modern" systems using a cam or crank sensor, which allows the ECM to actually "know" what the timing is.
Lars
To Timing
