Pulled engine, rebuild or crate?
Old Sep 18, 2014 | 08:40 AM
  #41
jb78L-82's Avatar
jb78L-82
Originally Posted by bluedawg
I agree 300%
oops!
I just did the same but cheated a little having a local engine builder handle all the short block items-pistons/rings, bearings, new balancer, balancing engine and then clutch assembly, polishing the L-82 crankshaft, reconditioning the rods etc. I pretty much did everything else. It was a great experience but a B*ll buster at times but would do it again in a heartbeat-no pun intended….
Old Sep 18, 2014 | 08:51 AM
  #42
SteveCurry's Avatar
SteveCurry
In the Oldsmobile world there are no crate engines so I've had to build many myself. The Chevy world however is a completely different story, you can get any size or flavor you want as a crate. I agree the first couple times it's fun to build your own, but after a while it becomes a PIA running back and forth the the machine shop, hoping the machine work on the block, crank and heads is done right, ordering parts, prepping parts, assembly. I'm older, I've been in the hobby a long time, crates are easier and that works for me. Plus most include a warranty against defects.
Old Sep 18, 2014 | 11:46 AM
  #43
lurch59's Avatar
lurch59
Originally Posted by 63mako
That said price and horsepower is great. You can build a 500 horsepower 383 for $5000 or $9000. Look at the parts list in the Ultrastreet engines. Dart SHP block and heads, Fully forged, Mahle pistons, High quality parts throughout.
Fast, durable, cheap. Pick 2.
EVERY time I cut a corner to save money on a high RPM and/or high HP build it comes back to bite me. I haven't bough from Vortecpro but have heard good feedback. Get a parts list.
Yes I know what you are saying, I remember looking at the parts list from VortecPro and was satisfied that they were quality: that being said I do not claim to have been following aftermarket parts manufacturers like I did decades ago. I know the ad from VortecPro says AFR heads.
I realize also that machine work is very important, my dad being a tool and die machinist making aerospace parts. It's hard for the average guy to evaluate quality machining.
I'm not disagreeing with what you are saying, but I took the short cut and did the research that I felt matters most, which is the engines make the power stated and they hold together based on lots of enthusiasts experience out there.
I've lost the receipts in my move or I would list them here. (The brand of parts)
Old Sep 18, 2014 | 12:12 PM
  #44
illenema's Avatar
illenema
Originally Posted by Super6
I've just broken in a 540 and I hope there isn't a new engine in my future, but if so, it will be a Shafiroff or Mark Jones crate.
Planning, knowing what you want and doing the research are very important, but you never know what will happen.
I've had 2 engines professionally built, both had instant rear main seal leaks. Both builders had 20 to 30 years experience. The second engine was supposed to be a 625hp 468, it made 525 hp as verified on a chassis dyno. That was 15 hp more than the 427 it was replacing. Heads didn't make the power they should have, porting and chamber work by the builder. He had a flow bench too.
I have a lot of parts, including 3 sets of BB cylinder heads, 2 in aluminum. So after the 468 failure, I bought a 540 short block from Shafiroff and planned on using a set of heads I already had. I got several recommendations for a local engine shop that specialized in cylinder head work. They ported the heads, flowed one and refreshed both. The flow results were hardly better than the stock numbers and all the valves, which they had lapped, were thrown in a box with all the location markings buffed off. What good is lapping the valves and then putting them back in the wrong holes?
Like I say, you just never know what you're getting.
Like your choices
Old Sep 18, 2014 | 01:29 PM
  #45
StingrayLust's Avatar
StingrayLust
Default decided to shelve the original #'s matching engine
I haven't been able to get this off my brain since I pulled the engine: crate or rebuild.
After talking with a local builder and the costs involved, and after all of that just having the block leftover and that's it, I think I'll be better suited by just buying a crate motor and storing the original.
For the price of the machine work alone on my block, I can get a new Dart SHP block that has 4-bolt mains, priority main oiling, built for roller lifters, and other goodies.
Old Sep 18, 2014 | 04:19 PM
  #46
illenema's Avatar
illenema
Those 2 mentioned above have it covered, When I swap out mine Im looking there first. Proven units
Old Oct 19, 2014 | 10:50 PM
  #47
C3Hawk's Avatar
C3Hawk
I decided to add a new view to an old "crate vs. rebuild" thread.
My (original block) 350 has been "rebuilt with performance parts" sometime ago. It does run pretty strong but does leak oil and without tearing it down I really don't have an idea what was done or what's left of it.
So here's my plan:
1. I am going to pull it and put in a crate engine so I can drive the car and have fun with the car while I....
2....tear down and inspect the "original" rebuilt engine and rebuild it if it is viable.
3. If the rebuild not worth it, I will leave the crate engine in the car.
4. If the rebuild is worth it, I will make something fun and put the "original" engine back in the car. Then I will go put the crate in some other car.
Old Oct 20, 2014 | 05:18 AM
  #48
Cavu2u's Avatar
Cavu2u
Same thing here.
This "factory" engine on my '73 is number matched to the frame, but it sure doesn't act like a 190 HP mill. Seemed like a whole lot more. So, before I tear it down (was consuming oil), I bought one of these to see if the previous owner changed the cam:
http://www.summitracing.com/parts/cca-4790
The car's performance says he did.
Steve
