MSD Distributor vacuum advice needed!
MSD knows that a lot of their stuff will be installed on engines pulling numerically less than 15 inches of vacuum, so they recommend running ported vacuum in order to keep the timing stable. Rather than running ported vacuum, run a B28 vacuum advance on manifold vacuum if you have engine vacuum in the 8-13 range.
This assumes you are running the ProBillet tach drive distributor, since you did not state which distributor you're using nor what type of car or year you're working on...
Lars
Lars
Lars
I enjoyed reading your posts, i am not working on a vette but i am trying to understand MSD distributor ported vs manifold. I was not able to send you a PM for some reason. I am running an all in one MSD distributor 8387 for a 70 charger with a 440. This distributor gives vacuum advance and the directions say use port, as you said if less than 15 vacuum, i will check my vacuum. If i use manifold and iam pulling more than 15, does the vacuum from the manifold add to the vacuum pulling from the distributor? I know little about this topic.
thanks
Lars
Jebby
thanks
Ok....did you get all of that? Now....the reason it is suggested to go ported with a low vacuum/large cam is that generally the overlap of the cam makes for sporadic vacuum at the manifold and if you put a gauge on it, it flutters a bit....this would cause a vacuum can to oscillate wildly....and the timing can be unstable using a light.
It is a lot to understand at first but I have taught this to dozens of guys and when they get it....really get it, they can tune damn near anything....from Vette's to a Rambler.....
Lastly, ported vacuum was used by GM and others to help NOx emissions at idle along with their pathetic initial "timing" specs. Millions of GM cars (and others, including your Charger) were about 10 degrees retarded from optimal from the factory. Street racers caught on quick and found out that proper timing and a set of headers on most of these old musclecars was worth about a second in the 1/4 mile (average).
My little brother has a 383 in his 69' Charger and I put an MSD ready to run in it 12 years ago......it was a slug when he bought it. I did the curve and put on a 750 Mighty Demon on the C3 Eddy intake......the first time we took it out.....we went to get beer up the road.....he wanted me to drive it back.....at night....so I hopped on it leaving the Party Store and it blew both airshocks and shot the damn packing out of the glasspacks LOL
No lie!Have fun.....440 Chargers are a rip....
Jebby
Jebby
Thanks a great story! I hope to see that kind of power one day!
Thanks!
Frank
thanks
