Intermittent Ignition Problem
Old Sep 10, 2014 | 08:46 PM
Jim78SA's Avatar
Jim78SA
Default Intermittent Ignition Problem
On my 78, I have been having this issue for some time now and I have no idea what is wrong. My car runs great all day long. Then, I will be at a stop light and all of a sudden my tach will jump around at the engine starts missing. If I don't hold the brake and accelerate at the same time, the car will die. Any ideas on what may be causing this?
Old Sep 10, 2014 | 10:11 PM
LT1driver's Avatar
LT1driver
maybe a loose wire somewhere around dist or tach wiring, better experts will chime in soon i am sure....good luck.
Old Sep 10, 2014 | 10:16 PM
mvftw's Avatar
mvftw
Ignition modules act funny when they get hot...cheap part to put in...
Old Sep 11, 2014 | 08:53 AM
Jamess411's Avatar
Jamess411
Usually a ignition module wil just quit until it cools down…but the tach jumping seems to indicate that exact thing. Is the tach going up and down…or only down with the loss of RPM??? Maybe the carb is loading the engine up with fuel ???
Old Sep 11, 2014 | 08:54 AM
Jamess411's Avatar
Jamess411
Lifter pumping down at idle with lower oil pressure??? Low battery voltage for the ignition caused by bad or corroded connections??? All possible
To Intermittent Ignition Problem
