Some technical help for you guys building an engine...
One question we get all the time is how do I measure for pushrods. We field about 4 of these a week from customers and others just needing some direction. I feel this is an area that the DIY guy is not comfortable with during engine building.
So I hired a videographer and last week we shot a video on how to establish proper rocker geometry so that one can find correct pushrod length. This is our way, Straub Technologies and my staff, to give friends, customers, and performance crowd something that they can use as an educational tool. The method Scott Foxwell uses in the video is the way that it is done here.
If the board wants to make the link to the video a sticky that is fine.
oops!
Engine building will weather you!!!!!
Here's where I'm a party pooper or I demonstrate my ignorance or both. I'm assuming that the pushrod length adjustment procedure takes place with the cam located at mid-lift on the valve in question. If the video is for a novice, like me, I'm not sure that point was made and it might be good to show how you determine that mid-lift position on the lifter.
I was born a sh-thead, I can't help it.
Excellent video by Scott Foxwell. It should be kept as a sticky.
If the cam lobe is on the base circle and the pushrod length is set to bring the valve to half lift, what happens when the lifter is at max lift? The first thing that comes to mind is ...coil bind? Something isn't making sense to me. Not trying to be a wise guy.
http://www.compcams.com/Pages/417/va...-geometry.aspx
1. howards and my engine builder BOTH stated that you do NOT have to use checker valve springs in the head on an engine staying below 6,500 RPM.
2. Not mandatory to calculate but lifter pre load for Howards roller lifter was .3/.4 on a dry lifter which i had to push to get from them if I was to add to the length using the adjustable pushrod checker. I did not use this value when calculating the length but I did soak the lifter in oil and manual pumped it up before I installed it in the block for the check--tip from my builder.
3. By far, the most important point is understanding that the rocker needs to move in an arch over the tip of the valve stem when you manual rotate the engine-see comp cam link above. When the roller lifter is on the base circle of the cam the rocker ball needs to be on the inside tip of the valve stem toward the intake, as you rotate the engine and the pushrod starts to move the valve open at mid lift-approximately-the rocker ball should be in the center of the valve stem, and at max lift the rocker ball should be at the other end of the valve stem towards the exhaust manifold side-an arch.
I used this technique and it worked perfectly. Am I missing something?
The other mystery solved was that pushrod length was unknown using retro roller and AFR heads. My builder stated that "normal" pushrod length for a roller cam is about 7.2 inches. He guessed with my AFR heads, the pushrod length would be 7.1-7.2. I measured 7.15 and that is what ordered. It turned out to be spot on....
Just a novice's experience...
Thank you so much
Please keep going on!
