Sticky Ignition Switch
Old Jul 29, 2002 | 05:41 PM
VettePower's Avatar
VettePower
Default Sticky Ignition Switch
My Ignition lock switch is starting to feel sticky when I turn the key. Is it okay to spray some WD40 in there to lubricate?? :flag
Old Jul 29, 2002 | 05:47 PM
JSB69's Avatar
JSB69
Default Re: Sticky Ignition Switch (VettePower)
I thnk I remember reading that some of the plastic in there is "allergic" to WD40. Check to papers on Corvette FAQ. I think this is covered. My guess is that it's down in the switch and not up where the key is anyhow.
Old Jul 31, 2002 | 11:19 AM
VettePower's Avatar
VettePower
Default Re: Sticky Ignition Switch (JSB69)
Can anyone else take a shot at this question?? :confused:
Old Jul 31, 2002 | 12:52 PM
john's '81 mouse's Avatar
john's '81 mouse
Agree that you probably won't get any improvement in you sticky ignition switch by spraying lubricant in the key tumbler area. Don't know about adivisability of using WD-40 for this purpose, I never use the stuff, but do have some silicone based spray lubricant I'd use...........have done so on other automobiles without problems. I use PB Blaster for the tuff rusted bolt/fastener situations.
I had a sticking ignition cylinder lock switch on my '81 when I got it, and 'fixed' by replacing with a new cylinder lock assembly. Lot's of small and plastic parts to remove to get at the thing when you have both tilt and telescopic steering along with turn indicators and cruise control wiring to deal with. You need a good assembly manual and removal/replacement instructions and a lot of patience , and a little luck that you don't break brittle plastic parts, to do this job.
Old Jul 31, 2002 | 02:34 PM
Schwee's Avatar
Schwee
I agree with John. In fact, replace the tumbler assembly ASAP.
My experience is that it will get stickier then suddenly, you can't turn the key at all. Hope you're in your driveway when that happens! Can't even tow it a few blocks if you can't turn the wheel.
Replacement is kind of a hassle, but cost only about $20 for the new key assembly and available and in stock at most parts stores.
Old Aug 13, 2021 | 02:07 PM
footloosiety's Avatar
footloosiety
1st Gear
This is an old thread I know, but my switch was 'sticky' in that sometime it would turn easily and sometimes you'd have to jiggle it a bit to get the key to move into accessory and start positions. After reading a bunch of ' I used Wd40 and it fixed it / Dont use WD-40' discussions, I settled on a combination of compressed air directed right in the keyhole with a small straw, and then put some light-grade oil I put on both sides of my key and tried to turn it back and forth multiple times. Just enough oil to ALMOST drip off the key when holding it on its side. Its been a few days now and the problem has seemed to go away. Easy fix for me at least...
Old Aug 14, 2021 | 03:52 PM
vettebuyer6369's Avatar
vettebuyer6369
Please dont post to a thread from 19 years ago, even if you say "I know its an old thread."
To Sticky Ignition Switch
