Help with C3 Search engine
Old Sep 11, 2014 | 10:13 PM
lonebull's Avatar
lonebull
Default Help with C3 Search engine
I would like to research detailed "headers with sidepipes on a 1976 smallblock" using the C3 search engine. I have tried several times & header info hasn't come up once. I see this exact item on page 3- "Headers for a 1976"- but when I type that in the search box even that post doesn't come up. I have a friend up in the northeast who asked me for a little help so I decided to try a search. I know the info is there as I have seen various posts over the years. Can someone tell me how to do a search for this & how to narrow the search to just the C3? My friend has a '76 with sidepipes & he was looking at Hedman-68280 but several on p.3 advise using Hedman 68301 or Summit SUM-G9003. Almost everyone on p.3 commented that installing headers was a simple bolt on but I remember lengthy posts concerning the sidepipe issue. How do I find those posts? I have a '78 with dual exhaust & no experience with Vette headers. Thank you. Lonebull
Old Sep 11, 2014 | 10:27 PM
Mooser's Avatar
Mooser
believe it or not, the CF search engine doesn't like extremely common or short words.
The best way to find something like that is to bounce out of CF and google it.
C3 headers 1976 corvette sb
Look for an entry that is from corvetteforum (usually the first or second) and at the bottom of that entry there will be three or four other other hits from CF and a link that says "more results from www.corvetteforum.com"
Click that link and you'll find that google will search CF way better for multiple words than the CF search will
If you only want to look at c3 sections (general, tech, etc) alter the google search to look like this
C3 headers 1976 corvette sb site:http://https://www.corvetteforum.com/forums/c3
The site bit with the forums/c3 will keep it only in the c3 sections
HIH
M
Old Sep 11, 2014 | 10:46 PM
lonebull's Avatar
lonebull
Thanks Mooser. Works like a champ. I appreciate it. lonebull
brianPA's Avatar
brianPA
Try searching on google.com for your search term and 'c3 corvette' or 'c3 inurl:forums.corvetteforum.com'. Google indexes this site and generally does a better job than the built in search.
EDIT - just saw Mooser beat me to it
Old Sep 11, 2014 | 11:26 PM
lonebull's Avatar
lonebull
Thanks Brian. Lonebull
To Help with C3 Search engine
