78 Heater
Old Sep 12, 2014 | 09:55 PM
Vette-kid's Avatar
Vette-kid
Default 78 Heater
someone teach me about my heater system. I'm getting ready to drop a new motor in my 78 and decided I needed to swap the heater hose and flush the core before I do. I ordered a set of hoses, wich came as two long rubber hoses. However, the old hoses are different. One has a section of hard line in the middle and the other has a vacuum operated switch in the center. Is this something that the previous owner cobbled together? I cant find much help on the heater in my FSM or repair manual. Im assuming its a shutoff valve, but I don't understand why the lines came as two long pieces when the old setup is 4 with a hard pipe in one and the switch in the other. Any help would be appreciated.
Old Sep 13, 2014 | 07:29 PM
caryb78's Avatar
caryb78
Default heater hose
The shutoff valve is actuated when you turn on the Air conditioning, it turn off the hot water to the heater core. I will look at my hoses tomm. and tell you what mine are like.
Old Sep 13, 2014 | 07:33 PM
caryb78's Avatar
caryb78
Default heater hose
I went ahead and looked. All my heater hose is rubber. Are you sure you are not looking at the hose to your air con. evaporator?
Old Sep 13, 2014 | 09:45 PM
Vette-kid's Avatar
Vette-kid
Nope, it was the heater hose. After pulling it apart, it was obvious that someone had cobbled it together, or "bubba rigged" it. Thanks for looking.
To 78 Heater
