Corvette Winter Storage ?
Old Sep 13, 2014 | 12:24 PM
adsvette's Avatar
adsvette
Default Corvette Winter Storage ?
Hi Guys;
Re: 1979 Corvette
What do you do to store your corvette in winter in a unheated garage ?
I'm in Ontario, Canada. January and February get very cold at times.
My main goal is to keep it dry and avoid possible freezing damage.
I'll make sure anti-freeze, other fluids, etc. are good.
Do you plug in a block heater ?
What about dampness, do you use a drying agent ?
Do you drain the Gas tank (or is that unnecessary) ?
Appreciate your thoughts.
Thanks,
David
Forgot to mention mine is 1979 Corvette, bought just 2 weeks ago.
Old Sep 13, 2014 | 12:50 PM
Ontario73's Avatar
Ontario73
For two winters now all I did was top up the tank and make sure the coolant was good to -40*C. I put a tight cover over it, but, nothing else. No battery monitor either. Starts right up in the spring, check the tire pressure, and off we go!
P.S. My car came from Innisfil where it spent most of its life!
Old Sep 13, 2014 | 12:53 PM
Mike Ward's Avatar
Mike Ward
Gee, three Ontario guys in a row!
I fill the gas tank, attach a battery tender and leave it alone. The sky-is-falling types will be along shortly with their must-do lists that would suffice for Armageddon.
Old Sep 13, 2014 | 12:57 PM
Ontario73's Avatar
Ontario73
Some people seem to forget that these things were 'just cars' for the first 20+ years of their life. Just about everyone of them was left exposed to the elements for a good part of that.
Old Sep 13, 2014 | 01:18 PM
hwcoop's Avatar
hwcoop
wash, wax, vacuum, Change oil& Filter, grease chassis, disconnect /remove battery, cover car Watch TV for 8 months
Old Sep 13, 2014 | 01:35 PM
Tim 1973's Avatar
Tim 1973
I'm sure glad our winters are very short.. Once my frame off is complete I would imagine I will do nothing for the 2 cold months. Might even get a few nice days to drive it. That's what I do with my street Rod...
Old Sep 13, 2014 | 01:46 PM
hwcoop's Avatar
hwcoop
That must be the week you guys get some frost
Some winters if there is no snow on the roads I'll take it out for a hiway cruise...raises the spirits to get me through the rest of the winter
Roads were Dry, about 25F
Old Sep 13, 2014 | 01:55 PM
Tim 1973's Avatar
Tim 1973
Yea we might get some below freezing temps for a week or two ...
Old Sep 13, 2014 | 02:48 PM
DZRick's Avatar
DZRick
Pest prevention is always a good idea too.
Old Sep 13, 2014 | 03:50 PM
EasyEd's Avatar
EasyEd
A couple sticky mouse traps can save your wiring. Ask me how I know.
Old Sep 13, 2014 | 04:18 PM
Paul L's Avatar
Paul L
I have gone commercial for 15+ years. Steady 60*F temps, free cover, no start, battery disconnected, secure, staffed and with alarms, etc. I just let it sit October to April. Bring on the snow and freezing rain.
Old Sep 13, 2014 | 04:58 PM
adsvette's Avatar
adsvette
Battery is the one thing I didn't think of.
What "Battery Tender" are you using ?
Old Sep 13, 2014 | 05:02 PM
adsvette's Avatar
adsvette
Thanks Guys,
Lots of good pointers, none over the top.
I want to make mine last at least as long I do.
Old Sep 13, 2014 | 05:55 PM
Paul L's Avatar
Paul L
Originally Posted by adsvette
Thanks Guys,
OK, so an unheated garage. Sounds good: out of snow and freezing rain. Take the battery out and store in basement on a piece of wood: not concrete (Wives' Tale #1, it works, the battery will die on concrete). You can get a battery tender at Canadian Tire but really you do not need it (pic). But it will not hurt. While you are at CTC get fuel stabilizer (Wives' Tale #2, it works.) Fill tank with fresh fuel. Do NOT set up on blocks. Get an oil change in October. Do NOT use a heavy cover, unless just a light breathable dust cover. Use "Bounce" dryer sheets in the interior and engine compartment to keep mice away. Do NOT start the car during the winter. Do NOT sit on vinyl seats at -20C. In other words just leave the car alone for the winter. April will come!
Old Sep 13, 2014 | 06:30 PM
midigike's Avatar
midigike
Also, I take steel wool and stuff it in the exhaust pipe openings to prevent Micky from making a nest in the mufflers. I also do moth ***** and a desiccant to collect moisture. Make sure you put that in a large container though.
Old Sep 13, 2014 | 07:11 PM
Mike Ward's Avatar
Mike Ward
I have one of these for each of the batteries in storage
http://www.canadiantire.ca/en/pdp/ba...-0111940p.html
Old Sep 13, 2014 | 07:17 PM
LS4 PILOT's Avatar
LS4 PILOT
Solution.....
Move south ...away from polar bears and that stuff...
I might put the top up Jan . Till late March.
To Corvette Winter Storage ?
Old Sep 13, 2014 | 07:36 PM
Paul L's Avatar
Paul L
Never saw that one at CTC. I only use mine when the car comes out of storage in April. It always starts up after commercial storage for six months but is a wee bit short of full load. But about five hours it is ready for summer....I wish we had one this year!
But I did struggle to enjoy about 1,600 miles. Not too bad.
Today was miserable; about 45*F and very wet. I actually turned the furnace on I was so uncomfortable inside the house. This is much too early.
Old Sep 13, 2014 | 07:48 PM
PeteL46's Avatar
PeteL46
Default Bag It!
You mentioned moisture; many years ago I purchased a "Bag It". It's a non-breathable envelope style cover. It has zippers on three side. I do most of the things described above, unzip the bag, open it up and drive the car on it. It instructs you to put desiccant under the car and inside. I put a light cloth cover on first and zip it up. It come out as clean as it went in
Paul L's Avatar
Paul L
Originally Posted by LS4 PILOT
Solution.....
Actually there is a certain beauty in winter. In a perverse sense I enjoy putting the Corvette to sleep and letting the white stuff come down. Then waiting for that DAY in April.
I signed my driveway snowblowing contract last week.
