Signal switch works dash lights
Old Sep 13, 2014 | 06:47 PM
j61man's Avatar
j61man
Default Signal switch works dash lights
I just reinstalled my new dash as I had to remove it to drill the mounting holes for my glove box door. After the replacing of all the dash pieces into their proper places I took the car for a ride and noticed that whenever I turn my signals or hazard lights on the dash lights flash on and off with the signal lights. I change all the interior light bulbs and outside signal bulbs to LEDs. I purchased 2 flasher units designed to work with LED (one for signals and one for the hazard lights.
I checked the ground wire on the drivers side bird cage where I added the two ground wires from the new flasher units. I removed the center console, center dash custer and speedo custer hoping to find that a screw punctured a wire by mistake but I still have the same problem
It is an 82.
Old Sep 14, 2014 | 10:28 AM
j61man's Avatar
j61man
Default I think that I am on my way to finding the problem
I just unpluged the front end wiring from the firewall wiring hub and the remaining lights are working fine. I guess now I will look for some bad wiring connections.
Old Sep 20, 2014 | 11:02 PM
j61man's Avatar
j61man
Default Wasn't the wiring harness
After removing the complete front lamp wiring harness and reconditioning it, I found out that it was not the problem. The problem was fixed once I removed all the front end LED light bulbs and the LED flasher units and replaced them with the old incandescent light bulbs and the old flasher units. I will probably introduce the LEDs later and slowly to see if I can find the problem with them.
Old Oct 23, 2025 | 11:48 AM
calvette88's Avatar
calvette88
I dont have power to the fuse
Old Oct 28, 2025 | 07:27 AM
big mort's Avatar
big mort
Following. The suspense is killing me.
Old Oct 28, 2025 | 09:15 AM
Alan 71's Avatar
Alan 71
Hello,
My question is:
If I go "way back" to this 2014 thread will I have as much hair as I did then?
Regards.....
PS: Does anyone remember the "way-back" machine?
To Signal switch works dash lights
