Engine not running more than a few seconds
Old Sep 14, 2014 | 11:03 AM
ATHANASE's Avatar
ATHANASE
Default Engine not running more than a few seconds
Here is where I really need some help:
The car has been running fine for years through regular maintenance.
This is a 1971 LS5 (454) with a Q-jet. Bought it 12 years ago and never had this problem. I drove the car last weekend and didn't notice anything unusual.
The engine would fire up but won't hold idle. Stops immediately. To keep it running, I would have to keep it in the 2000 rpm range or more. Plus it doesn't run smootlhy and is kind of reluctant to rev in the 3500 rpm zone. Like if I had a couple of sparkplugs disconnected (I checked, they are not).
I questioned the fuel supply and looked at the fuel filter. Dirty. Time to replace it which I did. No change, still the same problem although there is no doubt I am getting plenty of fuel there).
When the engine quit, the carburetor "coughs", throwing a small cloud of gas in the air (one time, the cloud caught fire).
Any suggestion on where I should look at is welcome.
Old Sep 14, 2014 | 11:35 AM
gerry72's Avatar
gerry72
You could be dealing with an ignition problem (points closing up, condenser going bad) or a bad timing chain. Just two possibilities of where to look based upon the description and the assumption the engine is as the factory built it.
Old Sep 14, 2014 | 11:42 AM
Walt71's Avatar
Walt71
My '71 (base 350) had about the same problems. Check the exhaust butterfly valve (not sure if the LS5 has one?) to see if it's sticking closed. And perhaps you'll need to rebuild the carb - my RQJ was 'professionally' rebuilt, but the floats were off and jets were clogged and the wrong size.... You say you're getting plenty of fuel to the carb, but is the carb delivering the fuel to the intake the way it should?
Old Sep 14, 2014 | 08:27 PM
ATHANASE's Avatar
ATHANASE
I checked the distributor and rotor: The are clean, beside a little bit of red dust. Ignition points look fine: clean and moving. I don't know how to check the condenser.
Iginition coil gives me the same # volts at the (+) and at the center connector to the distributor (6 volts ?!?!).
A bad timing chain is probably way beyond my skills to assess but could it go bad while sitting in a garage for a week and not giving any warning sign the weekend before?
Old Sep 14, 2014 | 08:34 PM
ATHANASE's Avatar
ATHANASE
I am not sure what you call the "exhaust butterfly valve". Can you elaborate?
I don't know if the carb is doing his job or if the problem comes from elsewhere. I wish I could have someone help me go through the diagnosis process.
Carb rebuild: Does is typically involve replacing parts or just cleaning parts ?
Old Sep 14, 2014 | 08:45 PM
kjbuster1's Avatar
kjbuster1
Default Exh. Valve
I believe the exhaust butterfly valve mentioned is the heat riser valve located in the RH exhaust between the manifold and the exhaust pipe. I doubt this is your problem. Lots of time is stuck open or closed anyway.
Old Sep 14, 2014 | 08:53 PM
BB2B's Avatar
BB2B
sounds like a fuel issue, perhaps the float is stuck?
Old Sep 14, 2014 | 08:54 PM
GUSTO14's Avatar
GUSTO14
Passenger side exhaust manifold, between the manifold and the header pipe. With the engine cold (cool to the touch) grab the weight on the side of the valve and flip it back and forth. It should move freely. If it doesn't move freely, try to move it back and forth to free it up. Spray some penetrating oil on it as well. If there is no weight, the valve has likely been replaced with a plain spacer, in which case... never-mind!
https://www.paragoncorvette.com/p-35...alve-rh-2.aspx
Good luck... GUSTO
Old Sep 14, 2014 | 08:57 PM
blue427's Avatar
blue427
did you check the dwell on the points?should be 28to 32 degrees(30 degrees always worked best for me when I had points) If I remember correctly a coil with points should have about 6.72 volts to 8.6 volts to run points,yours seems low.A bad condenser and it won't start at all.
Old Sep 15, 2014 | 03:56 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Maybe choke needs adjusting
Old Sep 15, 2014 | 08:30 AM
ATHANASE's Avatar
ATHANASE
Good luck... GUSTO
Thany you for the precision. I'll look at this too.
Old Sep 15, 2014 | 08:32 AM
ATHANASE's Avatar
ATHANASE
Thanks for reassuring me. The coil is in upper 6 volts indeed. I take this is not the problem. Thanks.
Old Sep 15, 2014 | 08:33 AM
ATHANASE's Avatar
ATHANASE
Which means taking the carb apart, right?
Old Sep 15, 2014 | 09:16 AM
LS4 PILOT's Avatar
LS4 PILOT
Something sounds clogged to me in fuel delivery. Like there is trash in the lines, filter , carb jets . When you rev the engine , the pressure shifts the trash from letting fuel pass.
Could be the excuse to overhaul the carb you've been putting off too long.
Is there any knocking or tapping noise from the valve train not normal to your ear.
Old Sep 15, 2014 | 10:16 AM
Tom454's Avatar
Tom454
Typically, when the vapor/fuel in the area if the carb air horn (top of the carb) catches fire, a "spark" is needed to kick it off. If you're not lighting it with a match, the spark is coming from inside the engine. In a correctly functioning engine, the valves are closed when the ignition sparks occur. So either the ignition system is providing spark at the wrong time, or the engine isn't closing the valves when it should be. This points to a timing issue (points, distributor housing rotation, plug wire crossfire, plug wire mix up, etc) or mechanical engine failure- valve sticking, timing chain/gears etc.
Test 1
Check the distributor to see if it rotates by hand easily. It should be locked down & not rotate. If you have a manual trans, put it in neutral.
Test 2
Remove the distributor cap and rotate your engine by hand until the distributor points are fully open and verify the correct point gap.
Test 3
While the dist cap is still off, rotate the engine clockwise/counter clockwise while observing the rotor movement. A large "dead spot" where the rotor doesn't move when the engine is rotating back & forth indicates a severely worn timing chain & gears.
Test 4
A compression test might help identifying a sticky valve.
Old Sep 15, 2014 | 10:37 AM
ATHANASE's Avatar
ATHANASE
So, based on all your suggestions, here are the two areas I am going to focus on:
1) Timing: Probably more the timing belt than the distributor / ignition points which look fine, but I will conduct the tests 1 to 3.
2) Carburetor: Consider a rebuilt.
Thank y'all. I'll keep you posted.
Old Sep 15, 2014 | 09:18 PM
GUSTO14's Avatar
GUSTO14
2) Carburetor: Consider a rebuild... not a rebuilt.
Fixed it for you...
Most on here would recommend against purchasing a rebuilt Quadrajet from a typical parts house. Because GM in particular actually sold so many varieties of the Quadrajet, every one different in someway from another version, many rebuilt Quadrajets end up with a Hodge-podge of parts in them. Few will work as well as an original that has simply been rebuilt by a competent technician. I have rebuilt a number of them over the years with a quality rebuild kit, and never been disappointed. They can always be rebuilt better by someone such as "Lars" or "Cliff Ruggles", but even I can do better than most autoparts houses seem capable of.
If you do feel inclined to tackle rebuilding your Quadrajet, do yourself a favor and pick up a copy of Cliff Ruggles book, "How to Rebuild and Modify Rochester Quadrajet Carburetors". If nothing else, you will end up amazed at just what these carburetors are capable of.
http://www.cliffshighperformance.com/buy_book_2.html
Good luck... GUSTO
To Engine not running more than a few seconds
