Lifter tick on start up
Old Sep 15, 2014 | 07:13 PM
540 vette's Avatar
540 vette
Default Lifter tick on start up
I have a new 383 in my 80. It has the Edelbrock top end kit with the Performer RPM roller cam. On start up I get some lifter tick and then it goes away after a minute. Something to worry about? New motor with 10 miles on it, plenty of oil pressure.
Old Sep 16, 2014 | 01:53 PM
MelWff's Avatar
MelWff
incorrectly adjusted rocker arm?
Old Sep 16, 2014 | 08:49 PM
540 vette's Avatar
540 vette
It goes away when the car is running a minute.
Old Sep 16, 2014 | 09:31 PM
LS4 PILOT's Avatar
LS4 PILOT
Loose or leaking exhaust manifold gasket . I had one crack that was near new ....replaced ticking went away. .....I ve seen many cracked iron manifolds do this too.
As engine warms ...expansion cuts down the leak in the exhaust.
Old Sep 16, 2014 | 10:00 PM
gcusmano74's Avatar
gcusmano74
What motor oil are you using? A thicker oil takes longer to get somewhere useful than a thinner one. Probably, you can use a 5W30 oil in a new engine, but check with your engine builder first.
Old Sep 17, 2014 | 01:38 PM
540 vette's Avatar
540 vette
It's not an exhaust leak. Checked that.
Old Sep 17, 2014 | 01:39 PM
540 vette's Avatar
540 vette
I have 10w40 in it now. Maybe I will try something a little lighter.
Old Sep 17, 2014 | 03:21 PM
MelWff's Avatar
MelWff
Default Noise
Did you use a length of rubber hose to hear if it is coming from the valve covers when cold
Old Sep 17, 2014 | 06:51 PM
540 vette's Avatar
540 vette
It's a lifter noise. The only reason I am asking is this is the first time I am using Edelbrock performer rpm roller lifters and wanted to know if the noise at start up is normal.
Old Sep 17, 2014 | 07:13 PM
DUB's Avatar
DUB
DID you prime the engine BEFORE cranking it????
Is it still 'ticking'???
I will write this...i installed a set of roller lifters form another manufacturer....and even though I primed the engine and manually turned the engine slowly while priming it ...the lifters stuck...and made noise like crazy. I removed the intake...removed the lifters and disassembled them...cleaned them up...oiled them manually in a fixture on my drill press...put them back in and had no further problems since. The factory assembly lube was the culprit used during assembly of the lifter. NEVER Will make that mistake ever again..
DUB
Old Sep 17, 2014 | 10:55 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
DUB
I had the exact same issue with a set of Comp roller lifters. Pulled the intake, rockers, rev kit, lifters, sent them back. Comp replaced them. Reinstalled, no problem, Lots of work!!! The assembly lube was the issue. They changed it now because of multiple problems with the old lube.
Old Sep 18, 2014 | 06:56 PM
DUB's Avatar
DUB
YEP...I did not want to name the name brand...but you are CORRECT. Actually Comp 'ticked me off' so badly....due to making me feel like the problem was my fault....And NOT having any paperwork/instructions in the box stating that you need to disassemble them and clean them and lube then before you put them in.
I do not have a problem in doing what is instructed....but I wish that they would say..."You are buying part that is INOPERATIVE...but it can be a great part if you spend gobs of your time in getting it to work as designed.
They got me once...NEVER AGAIN!!!
DUB
Old Sep 18, 2014 | 07:41 PM
TWINRAY's Avatar
TWINRAY
I'm 5 maybe 10 minutes from you, PM me if you want me to look at it. I'd use either 10-30 or 15-40 Delo both with Red Line EOS. 10--40 I do not like.
Old Sep 18, 2014 | 07:45 PM
TWINRAY's Avatar
TWINRAY
NO "noise" is normal whether at start up or any other time IMO.
Old Sep 18, 2014 | 10:06 PM
ajrothm's Avatar
ajrothm
Morel HYD roller lifters make a bunch of noise when cold, but usually quiet down to the normal "sewing machine" sound when hot.
You could go over your valve adjustment again and check preload etc etc but.. From my experience with several sets of aftermarket HYD roller lifter sets, the preload doesn't seem to have a huge affect on noise on cold starts...especially on the morels.
If I were you, I'd run thru the valve adjustment just for peace of mind... Then let it ride.. If they are quiet when hot, they're fine. 10w40 oil is fine...
My Morels in my 496 clatter like mad when cold, preload has been anywhere from 1/8 turn to 1 full turn.. Made no measurable difference on cold start rattle..
My LS7 lifters in my 402 are dead quiet cold and hot...ironically..
Even my wife's bone stock G8 with the 6.0l has some lifter clatter on cold starts.
You learn to live with it..
Old Sep 18, 2014 | 10:20 PM
540 vette's Avatar
540 vette
Ever own a C5.
Old Sep 18, 2014 | 10:24 PM
540 vette's Avatar
540 vette
Thanks for the offer. I was just curious if the edelbrock lifters made noise at start up. I just wanted to see if anyone else had used them.
What town are you in.
To Lifter tick on start up
Old Sep 18, 2014 | 11:31 PM
Rebelrob's Avatar
Rebelrob
I agree with Alan, I got the same noise at cold start up. I have Morel Hyd roller lifters. Typically once the temp gauge reads past 140-150 it quiets down, then sounds like a sewing machine as described above at operating temp.
Old Sep 19, 2014 | 06:32 AM
540 vette's Avatar
540 vette
Mine quits down after about a minute maybe less and then you hear normal valve train noise.
Old Sep 19, 2014 | 08:55 AM
TWINRAY's Avatar
TWINRAY
pm sent
