Well my shock mounts are proving to be a real pain as have for many others! After reading a few threads on here I have tried to remove them and failed. After reading how a few burnt out the rubber and spread the center collar on the lower strut rod end. I decide to cut the rod instead and using a small grinder for the ends I was able to cut it w/o hitting the trailing arm and then turn it and make another cut to remove it and then the rubber, because I didn't want to burn it off and stink up my garage. Then I saw my center collar was solid with no slit to spread and spray pen-oil into, so I then cut it in half hoping the end would then tap out since I couldn't even get the nut off.
Well that didn't work!
I don't have torches and really don't wanna remove the trailing arm. I'll beat on it some more with a BFH, but I figured it was worth asking while I take a break.
Spray the crap out of it with pbblaster...let sit overnight. Do not hit the shock mount directly.Use a piece of wood to protect. Use brake grease on mount when's installing new shock. You may have to burn it off with propane or mapp gas if that does not work. You don't need a torch.
Order new shock mounts. Chances are that your old ones are going to be unusable by the time you get them out. You can buy pipe caps at the local home center that will do the same job as the specialty tool that you can get from Corvette vendors.
The basic problem is that the shock bushing insert rust-welds itself onto the shock mount making it impossible to pound out the mount. Sometimes penetrating oils help but most of the time they don't. You will probably have to saw them into pieces to remove them.
If your trailing arms are in bad shape it might be worth it to take them off and trade them in to Van Steel for a set of rebuilt arms.
Getting shock mounts off is potentially one of the most difficult jobs on a C3.
I've been spraying all the bolts for everything with PB for awhile on the rear supension. Yah I'm pretty much screwed and decided to switch gears and mess with it more later. I got new offset TA's just don't have all the stuff to put it together and wanted some new spindles(tom's) but $ is tight atm. Forgot I read about the shock mounts being such a pita in my rush to get it done, wish I rem before I started taking it apart. I almost bought some last winter, but my C4 budget made me cut some stuff for my C3.
At this point I can't afford to replace everything that will crumble when I take it apart, so time to dust off the mustang.
edit: Also the strut rod bots were kinda greasy when I started and the car has only about 40k and been stored a lot of it's life(my dad bought it new), so I really didn't expect this much of a problem.
The shock mounts are about $35 each on Eckler's I believe. When I removed mine I actually cut the mount on either side of the strut using a cutoff wheel. I then was able to spin the shock side (front side) of the shock mount, because only the rearward part of the shock mount has the flat. After that a punch through that hole knocked the other side out pretty quick. Yes, this was a "Bubba" method, and I'm not proud of it. But it did work with no damage to the trailing arm (just be careful with the cutoff wheel.)
My plan was to cut the center beat the shock side out and then air chisel the nut side out. Can't get the shock side out so looks like I'm gonna have to replace the TA and all.
Nope I beat up and down or out and it's not moving, even tried to put a pipe on the shock end and pry up n down. Pretty sure I'll have to use my other TA's.
This might be too late, but you can try what I did. You can go to any
Auto Zone or O'Reilly's and borrow a pickle fork and try driving out the
shock mount. It doesn't cost anything for the loan. You just leave a deposit
and when you return the tool, you get your deposit back.
Get a tie-rod pickle fork not the ball joint.
Here is a shot of how I did mine.
My lower strut mount came out pretty easy. Lucky me. My question is , should this part have a slight bend or should it be straight down both lengths?
Both mine were pretty bent but my dad use to drag race the car and I read some people would bend them to correct for squat or something. I should have taken a pic and it's prob why I didn't break anything for the few years I drag raced the car myself. Still the rubber was coming out on the trialing arm end on one side and I should of change the prob stock shaft u-joints long ago.
Donnie
Let me be clear for any who read, because it took awhile before I found these details. On each end there is something that makes it so the mount will not twist and has to come out straight. So even if you cut it in half in the center, neither end will rotate. The castle nut end has a D lock & the mount L end has a knurl.
Mine was nowhere near as clean as that pic LOL Still not as bad as others I've seen. I had to cut the camber rod bushing end on the trailing arm, then cut the rod itself and twist it around some and made another cut to remove it. Cut the rubber off with a razor. Use a air chisel to separate & remove not one but two rusted sleeves(a sleeve in a sleeve on each end & this took the most time). Still with map gas and the air chisel I couldn't drive the shock mount thru so I had to make two cuts and take a center chunk out. I drove the D-lock end into the center and out with air chisel, next heated & drove out the knurl end from the D lock hole.
Hope this helps any who has rusted shock mounts.
edit: Oh and my cotter pins weren't gonna come out so I just cut the castle/lock part of the nut off and they came off with some muscle.
I cut the strut rod. I am going to install adjustable anyway. then pressed them out on the big press. I am reusing the shock mounts. New adjustable rods are $109 a set!
