Suspension Upgrade Help
So I need some help on a suspension upgrade and hoped you guys could point me in the right direction if I told you what I am hoping to achieve. I don't plan to race the car, but may do an autocross event here or there for fun. I want a nice lowered stance, but I would like to have the ability to change ride height depending on wheel and tire combo or other reasons. I want to stay around $2K or less. I have been looking at the coil over kits like Shark Bite and Vansteel. I think coil overs are the only way I can get ride height adjustment. If I had to put a label on the what I am going for I would say I am going for more of a pro-touring set up.
http://www.vbandp.com/auto-parts.htm...category_id=54
(Don't forget VB&P gives you a 10% forum discount too - but not positive if it applies to the kits?)
More important than the arrangement of how the springs and shocks are actuated is to get their rates and valving right for the task at hand. And, anytime you start heading towards the AX/RR corner of the performance envelope, adjustability is increasing valuable. That said, coil-overs in and of themselves are the superior technology, so long as you have sufficient funding for everything else needed to take full advantage of them.
Suggest reading up on the Chevy Power C3 Corvette chassis section, at a minimum. It doesn't cover everything, and may be showing a few signs of becoming dated, but it's still a solid foundation on which to build when getting serious about setting up the C3 chassis. The following are a few tips from my setup philosophy, a good bit applicable to any car, tho vastly oversimplified here...
Kits - Don't assume that any pre-packaged kit is necessarily going to be the optimum combination of bits right out of the box. The perfect setup is hard to come by, even at the top levels of racing, so it isn't very likely that you're going to get there with a single click of the mouse. Take advice as to specific specs the same way. In any event, you might as well go ahead and accept that you'll probably end up with a collection of various springs, bars and other such items before you're done.
Tires - Don't skimp here, or you won't ever get the most out of the rest of the bits you install. And, put them on appropriately sized wheels. It is vital to have a pyrometer (preferable a tire probe type, but an IR is better than none) and to learn how to read tire temps. This info will tell you things about your setup that you just can't get from a stopwatch or feel with your backside.
Chassis - Stiffen it as much as is practical so as to better facilitate the suspension being left to do its job. At a minimum install a spreader bar.
Weight - Remove unnecessary (to you) weight without compromising safety or stiffness. Reducing unsprung weight is always a good thing.
Geometry - For track day ride heights, see the Chevy Power specs. Bumpsteer your front end. Also, I highly suggest taking appropriate steps to minimize the affects of adverse rear toe-steer inherent to the C2/C3 IRS and to reduce (not necessarily eliminate) rear camber gain.
Springs - This will admittedly run contrary to everything those who prescribe to the BBSS (big bars, soft springs) school hold true and holy... Since springs contribute to anti-roll stiffness without the penalty of increased weight transfer (as results with adding bar), and AX/RR courses are typically smoother than the street, I'd urge you to run the highest front springs tolerable on the roads you most often drive. This will minimize how much you must rely on bar(s) for anti-roll. Besides, bars don't do anything to combat nose dive under hard braking. Try not to run more rear spring than is necessary to control anti-roll stiffness relative to the front, and to combat excessive squat under heavy acceleration. If you're not on the high-banks or drag racing, an F41 rear spring will be plenty in many cases.
Shocks - Again, don't skimp here. They're not only for dampening unsprung weight oscillations, but can and should be used to regulate how weight transfers as the car enters into and exits from corners. Of course, you can't tune them if they're not adjustables, preferably 2-way if you're new to them. Order thru the racing/tech department of whatever resource you choose (Koni, QA1, Penske...), who should definitely be asking you a number of questions important to matching a set to your individual needs.
Bars - Think of them as crutches for supplemental anti-roll and balance tuning, rather than as the primary tool for such. Despite what you may have seen or heard, it is entirely possible, even preferable, to sort a C2/C3 chassis without a rear bar. Remember, adding bar, while increasing anti-roll, actually reduces available grip at the end of the car in question, and no car can corner any harder than the end with the least grip.
Alignment - Once everything is in place, this detail can make or break how the package operates. Consider any recommended specs as only a baseline from which to work.
Tuning - Only make one change at a time so you know what actually helps and what doesn't, and only test how those changes affect your car at its limits in a safe environment. Other than possibly on a skid pad or at less than a car's actual limits, there is really no such thing as "neutral" balance. Get steady state balance dialed in first, then use the shocks to change how the car transitions into and out of the corners. Beware of getting caught up in your own (or anyone else's) preconceptions, and don't be afraid to try new things, especially shock settings when arriving at a new course. That's how you'll learn.
There's obviously much more to this, and I've left out a good bit regarding just how to go about putting the above into action. But, I do hope that helps get you going in the right direction, or at least gives you a decent reference point against which to gauge where you're heading.
TSW
https://www.corvetteforum.com/forums...ld-thread.html
For the Rear-
I'd recommend the Vansteel rear coilovers- you can sell you old stuff and ask Vansteel for 10% off for being a Forum member...Nets out to a little over $1K after you sell the old stuff
For the front-
The full deal coilover from Vansteels is nice and expensive...You can fudge a little here and run the semi-coil overs. After new balljoints and redoing your stock A-arms you are under $1K. I originally bought the semi but then decided to go w/ the full coilovers and tubular A -Arms- at a budget busting $2k+...However I sold my restored a-arms for about $450....
Budget buster-
TSW
Also, here's a link to an article on Danny Popp's '72 Vette who won the 2013 Holley LS Fest and missed winning this year by 1 point.
Danny Popp's Raw C3
By the way Danny runs a rear antisway bar as well. Just sayin'.
TSW
update - FWIW, I haven't forgotten about creating a stand-alone thread on this, just haven't yet had the time to write an opening post worthy of the topic... And, BTW, the presence of bars isn't necessarily evidence of a BBSS setup. Just sayin'.
Danny Popp's Raw C3
