It's a common problem on GM tilt steering columns. You have to pull it apart and there is 3 big Phillips head screws in the there. They loosen up and that's what gives you the wiggle. It will only get worse over time. If you never been deep into a GM column. Watch a few YouTube vids first or pay someone. I would say it's about an hour maybe hour and a half in labor but no parts to buy!
My Tilt & Telescoping Strg Column Disassembly & Repair Paper #1 has a series of quick tests described. These tests are conducted with the steering column in the car and should help you to zero into the cause of your looseness.
All of my papers are posted at the www.corvettefaq.com websit. I wrote them over a period of 13 years after my retirement from Saginaw Steering Gear Division, GMC. I am now way too old to even think about updating them with video.
I worked 39 years at Saginaw Steering Gear, (the last 2 years as Delphi). I was a supervisor in Steering Systems Engineering the whole time and bought two brand new C3 Vettes (1976 & 1980) and a used 1975 Vert. So I became very familiar with C2 and C3 components that Saginaw manufactured (i.e. power steering pumps, flexible steering shaft couplings, steering columns, power steering hoses, and manual steering gears.)
Sorry, no A/C experience.
Jim
Jim
Well thank you for taking the time to document your expertise! I know I speak for a lot of Vette owners when I say having things like this available is a great benefit!
