Kick panels?
My "with" AC '78, you need to fiddle with the AC control on the console to get them to open. I dont recall which setting opens them (assuming all the vac line are hooked up right). Somebody will be along with more info im sure.
dodosmike
bottom right of pic #1
dodosmike
Yep, two cars. The red 78 is in boxes now. The silver one is on the road. Drove it to work today actually.
Is yours NON AC? Any little **** to pull? In my first pic, imagine a fender on the car. The door being open would pull air from the cowl area. How "warm" that air would be would depend on how good a hood seal you have and the ambient air temp. I run with the heater hose closed (hot water shutoff) and the fan disconnected. Notice the fan lowest setting is "low" and not "off"? Pass side under hood, beside the hood latch, 3 or 4 wires on L shaped plug, pull it, the fan will stop blowing hot air. I run most of the summer with the tops off and windows down, Heat from the sun on my forehead is my biggest worry.
My silver car has AC, but unhooked by P.O. The compressor is in a box somewhere. Ive never had the desire or need to put it all together. I live 300 miles north of Buffalo NY. My summers are cool compared to the southern US. That, and I store my car for the 5/6 months of winter we have here.
Non AC cars, that door will open with vacuum (or lack of vacuum, I forget) depending on the settings on the console. As i mentioned, this all assumes that the hoses, springs, rods and all the other climate stuff is operational.
I think for next summer I might put the "pulls" on my vents to see what happens.
One way to tell on 78's if the car had AC originally is if the kick panels are fully carpeted or have a plastic opening, NON AC cars wil have a block off plate over where the two vents are above the center gauges and of course it will have the AC controls in the center console beside the fan control.
dodosmike
Here is a closer pic of the left side of the NON AC car. (Off topic but take note of the frame directly behind the tire...!)
If you can figure out where and how the air is blocked, this "cutaway" pic might help with unblocking it.
dodosmike
dodosmike
OUCH!!
The picture below shows the two openings being covered for the a/c cars.
