1976 stingray corvette help headlights and window problem please help!
Old Sep 25, 2014 | 11:30 AM
john53's Avatar
john53
Default 1976 stingray corvette help headlights and window problem please help!
I have been working on my vett. And i have no front headlights I have marker lights and turn signals, also my windows will not roll up?? Both problems happened at the same time I have checked all flashers bought a new head light switch for dash and replaced window relay. Also I can directly hook up the wires on the window realy switch and the windows will go up or down but only on the driver side. Please help??
Old Sep 25, 2014 | 07:27 PM
DUB's Avatar
DUB
The power windows have a wire that attaches in your fuse panel that may have come out....and as for you headlights...you need to look at the HIGH beam switch on the floor. It HAS TO WORK to make your headlights work.
Let us know what you find out.
DUB
Old Dec 27, 2014 | 11:53 AM
john53's Avatar
john53
Default help with windows! thank you but still windows wont work
DUB
The bran new floor dimber switch was bad, lol.
My windows will still not go up or down, I can buy pass the window relay and it started to roll up the driver window then stopped, I'm not sure what else to check!
p.s. sorry for taking soo long too message back. And thank you for the help!
Old Dec 27, 2014 | 11:56 AM
john53's Avatar
john53
Default I took the fuse box apart
I had power to the hook up on the fuse box but when I buy passed the relay and started to roll up the window stop I checked power to the hook up and had no power threw the fuse box Im not sure what other fuses there are really need help thank you!
Old Dec 27, 2014 | 12:34 PM
john53's Avatar
john53
and some of the buzzers wouldn't work after I buy passed the window relay that's what made me take apart the fuse box thinking that it was half burnt but after Taking it apart it seems it's only conectoins Really not a circuit board soo ruled that out I think.
To 1976 stingray corvette help headlights and window problem please help!
