Hood Quality
Old Sep 25, 2014 | 02:42 PM
BlackC3vette's Avatar
BlackC3vette
Default Hood Quality
Ecklers has a 77-81 fiberglass hood with 1 1/2" additional clearance. Based on the 80-81 stock design, it's part number is 38095. Do these hoods actually fit? Has anyone bought one that can give some feedback?
Old Sep 25, 2014 | 07:03 PM
DUB's Avatar
DUB
Hate to say it...it is a 'hit or miss' issue. All you can hope for is the best. And honestly...ti does not matter who's hood you buy. Due to it being hand-laid...there are variables that can be off a little bit...and knowing that no two Corvettes are the same...it is what it is.
DUB
Old Sep 25, 2014 | 07:13 PM
BlackC3vette
DUB
Having worked with fiberglass in the past, products coming from a mold and trimmed to size are usually pretty consistent. I was really looking for an option from somebody who actually purchased one of their hoods.
Old Sep 25, 2014 | 07:34 PM
DUB's Avatar
DUB
I have used Ecklers..along with many other companies hoods....I own a Corvette shop and customers will bring in hoods that they have bought...so I have pretty much see it all.
DUB
Old Sep 25, 2014 | 07:44 PM
Sunstroked's Avatar
Sunstroked
I bought an Ecklers hood. It's a BB/LT-1 hood. I would suspect made by the same vendor. Quality was good, but being it was a hand laid hood, the underside was textured. The fit was nearly spot on, a little blending here and there got a very acceptable fit. I did spend a lot of time sanding and filling the underside for a smooth appearance. And it did require a little filler and lots of block sanding to get a straight, glass smooth exterior. All in all I was happy, except they really need to package the thing better for shipping. I sent the first one back as the carrier damaged it. The 2nd one arrived and although the box was crushed, no physical damage occurred. Ecklers did compensate me for the time delay.
Old Sep 25, 2014 | 08:08 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I have an Ecklers L88 hood on my 75 and it fit pretty good.
I admit it was 35 years ago but still a good hood. They have probability thinned the material down somewhat in 35 years tho.
Hope this helps.
Old Sep 25, 2014 | 09:13 PM
BlackC3vette
Hope this helps.
Thanks for the info.
Old Sep 26, 2014 | 08:21 AM
jimvette999's Avatar
jimvette999
I've bought from Eckler's:
An entire front end
Fiberglass front bumper cover
Fiberglass rear bumper cover
High rise hood
The quality and fit has always been good. How well the hood fits your car will depend on the position your fenders are bonded to your fender wells. You may have to do body work/fitting to match the arch. There are also rubber bumpers used in the drip rail to affect the "arch". You may have to shim under the hinges to raise/lower the front. Be careful when reaching the latching stage because if you get the hood stuck on the latch pins because of a bad alignment, it may be quite difficult to get it to release so leave the latches off until that stage and then take your time aligning the latches. If they do get stuck, try sliding the hood port and starboard to get it to unlatch.
Jim
Old Sep 26, 2014 | 01:11 PM
bluedawg's Avatar
bluedawg
This is the Ecklers L88 high rise, if I were home I'd look to see actually manufactured it as there's a card under the glass. Fit and finish is fair.
DO MA NEU!
Old Sep 26, 2014 | 05:36 PM
BlackC3vette
jimvette999 and bluedawg
Thanks for the good info!
Old Sep 27, 2014 | 12:00 AM
bluedawg's Avatar
bluedawg
Your welcome. I will say that sitting in the cab looking out past the 4" high rise gives you a some what sinister feeling.
DO MA NEU!
Old Sep 28, 2014 | 08:20 AM
diehrd's Avatar
diehrd
I have the hood your talking about , all i had to do was work out alignment issues .. Once that was set it was prep and paint ..
Old Sep 28, 2014 | 11:12 AM
BlackC3vette
Did the alignment issues involve grinding or just positioning? How does it look? My other choice for a hood was the Stinger.
I think I need to either put a different intake manifold on or buy this hood real soon. The offset, dropped (Allstar) air cleaner just sits way to low on the carb. It sits so low that I had to take the air baffle off the top of the Q-Jet just to get the air cleaner top on.
To Hood Quality
