I am curious if anyone has any solution to lessen the effects of the brakes locking the wheels when braking on wet roads. I live in Florida where it rains quite frequently and i dont like to let rain stop me from going out. I read in another thread one member preferred to use FF brake pads as one solution. Obviously it takes a little skill beyond braking in an abs equipped car but im just curious if there's anything more i can do especialy since living in miami hard stops are frequent and necessary to stay alive and are a little scary without abs on a wet road
My first thought is that you need tires that are better in wet conditions. What kind of tires are you using and is there plenty of tread on them?
If a persons driving style requires that they rely on the availability of ABS to keep them out of trouble, the tires, brakes or type of car is not the problem.
I'm working on my own skill, but its incredibly easy to lock up in the rain when you need to hard stop on a highway going 70-80 mph
...its incredibly easy to lock up in the rain when you need to hard stop on a highway going 70-80 mph...
Excuse me, but any C3 is likely to lock up on wet roads trying to stop from 70-80 mph. In those conditions (wet), why would you need to be traveling at 70-80 mph?
It sounds like your brakes and tires are working well. As has been said it now comes down to driving style and that is not saying you are the issue.
Back in the day before ABS was invented we had to learn to pump the brakes to maintain control and adjust driving style for the conditions at hand. I grew up in the snow belt and learned to drive with non ABS cars/trucks. If the roads are icy we had to leave more space in front and watch the traffic more carefully. These Corvettes are old style cars that require older driving techniques in those conditions. I personally hate ABS and the fact that a computer is allowed to get between me and my braking plans.
In response to both mikes:
We're talking interstate highway driving here. I understand that these cars are likely to lock up under these conditions (more so with the hydroboost setup which makes the pedal very sensitive) but the goal here is to find out whether or not there might be a way to reduce this effect. Even using cadence braking at lower speeds (35-50) on wet roads is a challenge when some jack*** cuts you off and slams the brakes.
If it's over sensitive try a different brake pad. Some are really grabby and make it hard to modulate. My sons Mazda 2 is like that and I active the ABS all the time on dry roads.
I do try to leave myself more room in the rain but unfortunately other drivers in south florida are not of the most courteous sort, cutting you off and leaving less than a few car lengths to work with.
As far as tires go, unfortunately there arent very many options that allow me to keep my stock rims (i love the look). Ideally id throw some z rated tires on it but i have not found such an option in this size.
Its my understanding that FF rated pads have low grip at low temp making it a little less likely to lock up. Im currently using the oe organic ac delco pads
I've driven in Miami in such conditions. No worse than anywhere else. Quit blaming the car or the environment.
The C3 holds the pads against the rotors. If you are doing 70/80 they are not cold. When I drive 2 miles to work I measured 150 degrees by the time I parked.
I like the 1521 and use it all the time on all my cars.
"This compound's excellent linear torque production provides incredible braking force without ABS intervention." http://www.ctbrakes.com/brake-compounds2.asp
Folks, I say this all the time-The S/T rated tires available for the stock C3 rims are quite frankly JUNK!!! The Firestones, BFG Radial TA's etc are old technology tires with no performance at all. They are a standard passenger car tires with raised white lettering, low traction rubber, and poor tread design for rain. The reason tires have treads on the street is mostly for rain-that's it. Every car I own has Z rated ultra high performance summer only or all season ultra performance tires for real performance in the dry and especially the WET!!! My 78 has 255/45/17 ZR summer only ultra high performance tires that are AWESOME in the wet. You are flirting with disaster driving fast in the rain with stock OEM type tires.
One of the most important aspect of any car's handling, steering, and braking is the TIRES-tires are the car's only connection between you and the road-Don'tt skimp!!!
