intake bolts
Old Sep 27, 2014 | 06:57 AM
Yzordderrex's Avatar
Yzordderrex
Cruising
Default intake bolts
Do I need to put lock washers on intake bolts? I bought a set of bolts from Corvette America and there were no lockwashers.
regards,
Yzordderrex
Old Sep 27, 2014 | 07:12 AM
V4motorsports's Avatar
V4motorsports
regards,
Yzordderrex
No.
Russ
Old Sep 27, 2014 | 08:06 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
No...
Old Sep 27, 2014 | 08:36 AM
GUSTO14's Avatar
GUSTO14
If your manifold is aluminum however, it's a good idea to use a flat washer under the bolt head. One with a smaller outside diameter than normal will give you good clearance in the tight places and stainless steel works best to prevent galling of the manifold surface.
Good luck... GUSTO
Old Sep 27, 2014 | 09:04 AM
jb78L-82's Avatar
jb78L-82
Good luck... GUSTO
yes
Old Sep 27, 2014 | 09:15 AM
Yzordderrex
Cruising
Ok. I just had manifold stripped and powder coated. I don't want to gouge up manifold.
thanks
Yzord
Old Sep 27, 2014 | 06:48 PM
7T1vette's Avatar
7T1vette
If the bolts you have already have 'flanged' heads on them with a recessed undercut, you MAY not need lockwashers. If they are standard hex head bolts, you need lockwashers.
To intake bolts
