posi vs limited-slip?
Old Jul 31, 2002 | 11:42 PM
stingray72's Avatar
stingray72
Default Re: posi vs limited-slip? (jonjollyf4)
Positraction became standard on Corvettes starting with the 72 model year. Before that, it was an option, although it was a mandatory option on the high performance engines.
"Positraction" is a GM trade name. Chrysler called it "Sure Grip" differential. Ford called it "Trac-loc" or something similar. They are ALL limited slip differentials.
George
[Modified by stingray72, 9:44 PM 7/31/2002]
Old Aug 1, 2002 | 01:21 AM
1969Vette383's Avatar
1969Vette383
Ford= Traction-Loc
GM= Positraction
Chrysler= Sure Grip
Studebaker= Twin Traction :D I got well acquainted with that "T T" when I'd drive my dad's R3 Avanti (Blown 5.0 out of the factory) to high school
Old Aug 1, 2002 | 05:21 AM
Turbo-Jet's Avatar
Turbo-Jet
I'm curious. What is Zexel - Torsen anyway? Is it a type of limited slip?
A Torsen differential is a really slick device. Just like any differential, the Torsen carrier is used to drive two output shafts, allowing for different relative rotational speeds. But the really cool thing is how it provides a 'limited-slip' effect from torque biasing. The planetary gears will 'lock' under certain inputs just due to pressure angles of the invex gears. Torsens are what made Audi's Quattro famous, because it is just a set gears mounted in the tailhousing of the transmission, driving front and rear driveshafts. No clutches, no springs, no mechanisms. We used one mounted transversly in a custom housing for chain drive on our FSAE racecar.
http://www.torsen.com/
Here are some pics of ours:
[Modified by Turbo-Jet, 1:23 AM 8/1/2002]
Old Aug 1, 2002 | 10:11 AM
ZD75blue's Avatar
ZD75blue
Default Re: posi vs limited-slip? (Turbo-Jet)
shaweet!!
like that torsen thing... wow
I wonder how hard it is to fit one of those into a vette case?
It looks pretty trick... and the no clutches and springs caught my eye :yesnod:
How much do they run?
ZD
Old Aug 1, 2002 | 10:15 AM
ZD75blue's Avatar
ZD75blue
Default Re: posi vs limited-slip? (ZD75blue)
360 bucks a piece for the torsen... at that price... it gets the gears turning for me... why oh why :blueangel:
Old Aug 1, 2002 | 01:36 PM
gerry72's Avatar
gerry72
The TorSen differential is an awsome rear. There is a small problem with it in that it can't take regular high shock loads. If you were to use this type rear on a car that was drag raced, you would likely end up scattering the bias gears. For a car that doesn't see these clutch-dump launches or a lot of speed shifting they are hard to beat especially in road racing. The real dowside though is that applications are rather limited. They tend to favor the imports.
