posi vs limited-slip?
Old Jul 30, 2002 | 06:54 PM
Turbo-Jet's Avatar
Turbo-Jet
Default posi vs limited-slip?
What (if any) is the difference between Positraction and limited-slip differentials? I familiar with the terms '1-way' and '2-way' limited-slip, and understand they use spring loaded wet clutch packs to lock the half-shafts under certain conditions. I am also familar with Zexel-Torsen style diffs (using Invex torque-sensing planetary gears).
Is Posi just and old term? What type of gear oil should I buy?
Old Jul 30, 2002 | 06:59 PM
Larry B.'s Avatar
Larry B.
Default Re: posi vs limited-slip? (Turbo-Jet)
Paper bag- paper sack. Hoagie- sub- grinder.... Black top- Macadum.....you get the idea.. :lol: :lol:
Old Jul 30, 2002 | 07:17 PM
flood's Avatar
flood
posi traction is GM's name for their limited slip rearend.
Old Jul 30, 2002 | 08:35 PM
Techno's Avatar
Techno
Default Re: posi vs limited-slip? (flood)
And it locks up. Caddy claims thiers doesn't but I don't have it. Do have posi though and it does turn into a solid axle, so to speak.
Old Jul 30, 2002 | 08:43 PM
The Dude's Avatar
The Dude
Default Re: posi vs limited-slip? (silvervetteman)
You forgot tomayto/tomahto...
Old Jul 30, 2002 | 09:16 PM
jonjollyf4's Avatar
jonjollyf4
Can you tell what you have by looking at the Diff?? Or do you actually have to pull the carrier?
Old Jul 30, 2002 | 09:26 PM
Stingy74's Avatar
Stingy74
Default Re: posi vs limited-slip? (jonjollyf4)
I think all Vettes 68 and later had posi. Some of the oddball 3 speed cars and such had a right legger. Not sure exactly which cars but it's safe to say that 69 and later are all posi. I'd like to have an air locker some day, just like the 4wd guys.
Old Jul 30, 2002 | 09:30 PM
Fevre's Avatar
Fevre
Default Re: posi vs limited-slip? (The Dude)
Let's call the whole thing off. :)
[Modified by Fevre, 7:31 PM 7/30/2002]
Old Jul 30, 2002 | 09:46 PM
PRNDL's Avatar
PRNDL
I think that is it. I think positraction is a trademarked name - a GM trademark. But when you buy the GM "positraction additive" it doesnt say "positraction" anywhere on the bottle! Only "limited slip differential". Can be confusing at first!
Now, can anybody tell me what a "Delcotron" is?? :lol: My 68 service manual doesnt use the word "generator" or "alternator"..... only "Delcotron" !
MJ
Old Jul 31, 2002 | 12:49 AM
Techno's Avatar
Techno
Default Re: posi vs limited-slip? (MNJack)
Posi-traction is most definitly a trademarked name. Ford has one and so does Caddy.
Someone a while ago mentioned all Vettes from some year had Posi. 2 ways to check. floor it and both wheel should lock up. Or floor it on a turn.
Another way is jack up both rear wheels. turn one side and the other will turn in the same direction. No posi and the turn in opposites. I think.
If you can steer with your rear wheels and throttle you most likely have it.
Old Jul 31, 2002 | 02:22 AM
jonjollyf4's Avatar
jonjollyf4
I'll spin the wheels tomorrow. I'm pretty sure its pos though.
Old Jul 31, 2002 | 04:13 AM
Darkness's Avatar
Darkness
There is a difference between the two. Limited slip is just that, it alows limited slipage and posi-traction it give full traction = no slipage.
Paul
Old Jul 31, 2002 | 09:07 AM
gerry72's Avatar
gerry72
Default Re: posi vs limited-slip? (inferno-vette)
Paul
You must have gotten that perspective off an internet forum from some Supra guy. :lol:
A limited-slip in a type of high-traction differential. A posi-traction is the GM name for this limited-slip differential. A limited-slip is never locked, although it may appear that way. Both axles are free to turn at different speeds at any time. All they have to do is overcome the friction of the clutch packs. The preload from the spring or springs provides very little application force. The force comes from pinion gear torque. The more torque going through the pinion gears, the harder they push on the clutch assembly. All you need is an axle input torque differential (caused by uneven friction coefficients or different rotational speeds) to cause the differential to do its thing.
There are only two differential types that lock the axles together. The only one suitable for street use is the Detroit Locker (not available for the 63-79 Corvette 8.375" ring gear case). A spool is race-only piece. In a DL, the only way the axles will unlock is when cornering under light to moderate throttle. The dog clutches will not unlock in a straight line or even in a corner if there is sufficient torque going through the differential.
Really, this information isn't too hard to find through reputable drivetrain sources.
Old Jul 31, 2002 | 10:13 AM
Ben Taylor's Avatar
Ben Taylor
Default Re: posi vs limited-slip? (Stingy74)
I'm pretty sure that it started in 63, not 68.
Old Jul 31, 2002 | 10:35 AM
verskel's Avatar
verskel
Most '68 Vettes had Posi - but not all..... it was still an option for 1968. :yesnod:
Old Jul 31, 2002 | 03:57 PM
Bill W's Avatar
Bill W
Default Re: posi vs limited-slip? (verskel)
I don't have the Black Book in front of me but I believe that 70 was the first year that posi was standard on all ratios.
Old Jul 31, 2002 | 04:49 PM
Darkness's Avatar
Darkness
Default Re: posi vs limited-slip? (Bill W)
I just hape when people start insulting other without apparent reason, instead of mouthinn off , one should think if posi-traction is a GM trademark why then is ford using it too, why are off-raod guys using posi's instead of limited slip, why were some corvettes sold with posi and other with limited slip.
Posi looks about the same as limited slip that's right but normally a posi is a stronger unit than limited slip, it "grabs" more.
http://emporium.markwilliams.com/pro...=22&np=22&fp=1
http://www.markwilliams.com/pdfcat/pg14.pdf
No flames, just :cheers:
[Modified by inferno-vette, 12:50 PM 7/31/2002]
To posi vs limited-slip?
Old Jul 31, 2002 | 06:49 PM
Techno's Avatar
Techno
Not that it matters but if fords have posi its like calling pespsi a coke.
Fords- traction-lok
Cadillac - mentions controlled differential. It goes on to say that it isn't of the positive lock type. It will release before an excessive amount of torque is directed to one rear wheel. That doesn't make sense to me.
Forgot to mention. Limited slip is the generic term for the differential.
Posi-traction is a limited slip differential
Traction-lok is a limited slip differential Thats what you would see in a shop manual or owners manual.
Ones a coke and the others a pepsi but both are colas Most people say 'coke' when they mean cola. Same with posi.
[Modified by Techno, 6:06 PM 7/31/2002]
Old Jul 31, 2002 | 10:14 PM
Larry B.'s Avatar
Larry B.
Default Re: posi vs limited-slip? (Techno)
Posi-traction became standard in 1970.. It was an option in 69 but most 69's had posi as it was require for most engines and gear ratios. If you jack both rear wheels off the ground and spin one wheel by hand and the other wheel spins the same direction it is posi- . If the other wheel spins the opposite the it is not posi. Simple test... :D no :boxing boys
Old Jul 31, 2002 | 11:27 PM
jonjollyf4's Avatar
jonjollyf4
I'm curious. What is Zexel - Torsen anyway? Is it a type of limited slip?
