I've put true 2" dual exhaust on my 80 Vette. Everything else on the car is original including the carb (Quadrajet 17080204). A mechanic suggested that I might want to change the jets and metering rods because of the increase of air movement due to the dual exhaust. Anyone have experience with this modification and a jet change?
The only true indication is a dyno test. You probably couldn't tell by the seat of your pants. If you decide to change the carb, first read Lars' excellent papers on tuning these carbs. Also, make very small changes at any one time. In any case, simply changing to a dual exhaust is not going to make much difference in performance. Just do it 'cause it's cool!
First, make sure your distributor is doing what it should. Lars Grimsrud's papers are a great source of information.
Then, get Lars' papers on the Quadrajet, read Doug Roe's book, and also Cliff Ruggles'. Then, get yourself a dash mounted air/fuel ratio gauge and see what the carb is doing.
THEN, you might fool around with some rod and/or jet changes.
Or just ship your distributor and carb to Lars and have him set it all up for you.
As others suggested first make sure the ignition system is up to par. All the mechanical adv etc is working properly. Then look at your plugs to see how they are burning or you would need a AFR reading to see if any changes are required. Just blind suggestions usually dont lead to performance gains. Start from a base make 1 change and compare before and after. Before and after based on your seat of the pants feel would require a big change for you to notice anything. 1/4 track or dyno testing would allow you to measure before and after.
By making jetting changes I was able to gain .5 sec @ 1/4 runs, but the change required me to go to smaller jets not bigger ? Original jetting was to rich for better performance. I measured the AFR (air fuel ratio) to know which way to go.
Originally Posted by Teem66
1980 L48 Auto
Once you upgrade the exhaust to move more air with less restriction on the exhaust side, you need to bump the jetting up a tad. This is more important when changing over to headers than when just going over to dual exhaust using the stock exhaust manifolds. Normally, when going from manifolds to headers, my recommendation is to bump the jetting up 2 jet sizes. With your stock manifolds and the dual exhaust, you can probably get by with simply raising your float level to .300 and getting the APT adjustment up to the height recommended in my Q-Jet Setup paper. Make sure your carb has the correct 71/43/CH jetting in it. You can bump the jet size up to a 72 to be on the safe side along with the other 2 mods suggested.
Lars
Thanks everyone, especially Lars. Lars, I have your papers on timing and carb set up. Everything (I believe) is set up according to your specs. I'll follow these additional suggestions. Thanks again everyone for the help.
