Borgeson 999032
Old Oct 26, 2014 | 05:01 PM
PeteZO6's Avatar
PeteZO6
Originally Posted by thegazman
So, you are saying that if you have a good positive caster the main requirement would be the toe-in adjustment. Installing a Borgeson conversion shouldn't change your caster. Is that right?
For normal driving, I like lots of caster. Others will probably have different opinions, esp. If AutoXing, or road racing.
While you should have your alignment checked after installing the Borgeson, the Borgeson itself shouldn't have any effect on your alignment settings. Since you have to play with the relay rod, and maybe remove the tie rods from it, you should for sure check the toe setting.
Pete
Old Oct 26, 2014 | 05:08 PM
diehrd's Avatar
diehrd
Who is mudflaps ??? I need to order one was going o use Ebay for 670.00 shipped
Old Oct 26, 2014 | 07:04 PM
jrdestar's Avatar
jrdestar
Go to Mudflaps.com and you will get your answer. Great price 602.00 and fast delivery.
Old Oct 26, 2014 | 10:50 PM
Kim72's Avatar
Kim72
That's a hell of a good price for cars with stock power steering. Mine cost approx. $750 a number of years ago. You'll need a pump for manual cars.
Old Oct 27, 2014 | 05:55 AM
diehrd's Avatar
diehrd
Thank you,, Ordered !~!~!
