1972 c3
Old Oct 5, 2014 | 01:03 PM
rsonjohn's Avatar
rsonjohn
4th Gear
Default 1972 c3
Is there a solution to the issue of a 455ci being hard to turn over when the engine is warmed up and at operating temperature? Cranks over fine when cold but not when warmed up.
Old Oct 5, 2014 | 01:14 PM
bluedawg's Avatar
bluedawg
First off is it a 455" or a 454" not that it matters toward your question. Secondly toward your question, a new starter, probably a stock starter, but say there's something not elaborated to, a high torque starter might be better and if all else is good a starter would fix it.. But before you buy a starter, what is your initial timing set at, do you know more about the engine, compression, cam ect. Is it stock or modified? How long sense the last rebuild? What temp does it operate at? Does it have oil leaks at the valve cover? You might not need a starter, but with out knowing specifics were only guessing.
DO MA NEU!
Old Oct 5, 2014 | 01:50 PM
rsonjohn's Avatar
rsonjohn
4th Gear
Default C3 454
Stock engine, rebuild approx 5000 miles ago, operates at 210 deg. I did not rebuild the engine. I suspected the timing may be advanced to far, or possibly the starter may be weak, starts fine when cold, Have not checked the timing. what would be the correct setting above top dead center?
DO MA NEU!
Old Oct 5, 2014 | 02:36 PM
bluedawg's Avatar
bluedawg
I'd try a 160 or 180 degree thermostat, while 210 degrees is not off the chart, it's a lot higher than I'd prefer. Definently check your timing, and if it seems right, the next time you have starting issues try retarding it some, this might indicate that your initial is off or your curve is coming in to quick via worn out springs in the mechanical advance. It don't take much when a starter is worn down.
DO MA NEU!
To 1972 c3
