Under the valve cover
Old Oct 5, 2014 | 02:26 PM
Bfail's Avatar
Bfail
Default Under the valve cover
I have a 71 350 and just had side pipes put on. It seems to sound like a lot of air coming out of my left valvue cover. It's kind of a puff puff puff or puttering sound. It sounds like the noise is coming from underneath the valvue cover and NOT around the header gasket, so I am thinking this is not an air leak at least at the header connection.
Any thoughts?
Old Oct 5, 2014 | 02:51 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
We need more info. What type/brand of pipes/headers?
Old Oct 5, 2014 | 03:18 PM
Bfail's Avatar
Bfail
OBX Stainless Steel w/resonators
Old Oct 5, 2014 | 04:45 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
The OBX are made in China, however most here that have installed them have favorable comments about them. That said, I would bet there is still an exhaust leak at the flange. It does not take long on a running engine to burn and blow out a gasket.
There should be nothing under the valve cover to give you that same sound. Any leak of the valve cover would be blowing oil.
You might try retorquing the flange bolts as they often work loose as the gaskets burn in.
Old Oct 5, 2014 | 04:51 PM
Bfail's Avatar
Bfail
Interesting, there is definitely no oil blowing out of the value so that is good. The right pipe is noticeably louder with a funny sound, than the left driver's side pipe.
Old Oct 5, 2014 | 05:16 PM
7t9l82's Avatar
7t9l82
what inserts in your side pipes do you have?
Old Oct 5, 2014 | 05:22 PM
Scottd's Avatar
Scottd
Start your car when its COLD. While its running, take your finger and place it near, above and around the suspect noise. You WILL feel the jet of HOT gas coming out of your exhaust flange. You may want to double up on your exhaust gaskets. (Yes, put 2 gaskets on one side.) (How Ive run my last 350 and my 454)
Emphasis on doing this with a COLD engine. 1) the metal hasnt expanded to seal up any small gaps yet and 2) well, its gets real hot real quick and you dont want to burn off your fingers.
Old Oct 5, 2014 | 06:27 PM
Bfail's Avatar
Bfail
The inserts that came with the OBX pipes. Couldn't find any without, but I don't mind the sound, they sound pretty good.
Old Oct 5, 2014 | 06:30 PM
Bfail's Avatar
Bfail
I actually had them professionally installed, so I really don't want to pay a couple extra hundred bucks to have them take them off, put two gaskets on etc.
However, since there has been a leak, I am now wondering if the gasket it burned or blown out in that particular area. if that's the case, then I would say they are liable to take it off and fix it free of charge since this has only been about a month or two months max.
Old Oct 5, 2014 | 07:10 PM
OMF's Avatar
OMF
Yes, I have seen just the bottom part of a exhaust gasket blow out. It looks just fine when inspecting from the top, but placing your fingers underneath the flange you will feel exhaust gasses.
I feel there is no need to double up the gaskets.
After you replace the gaskets, it's a good idea to go around the header bolts and snug them up for the first week ( or several weeks if you just drive it occasionally.) You will know when they are good because they're not loose anymore.
Old Oct 5, 2014 | 08:29 PM
7t9l82's Avatar
7t9l82
i have the sweet thunder inserts and they have a fluttering sound at idle, thought you might have the same issue
take a lighter with a long reach and run the flame around the header gasket and see if it tries to blow the flame out anywhere. beats running your hands around it.
Old Oct 9, 2014 | 06:28 PM
Bfail's Avatar
Bfail
So, I found some interesting facts...My front right cast iron thread is stripped (this was not where the leak was coming from.) Looks like some work is needed there and also all the screws were tightened on a hot engine (still a leak on the left back flange screw.) Hopefully torquing them down on a cold engine will solve that problem if not...I am SOL with a mad face!
Old Oct 9, 2014 | 07:08 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The headers do NOT have to be completely removed to replace an exhaust gasket. All you need to do is remove the flange bolts, pullout the (bad) gasket, slip in a new gasket, and re-torque the bolts.
Old Oct 9, 2014 | 08:01 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Try these metal gaskets. Best gasket I've ever used.
http://www.summitracing.com/int/part...6012/overview/
Old Oct 12, 2014 | 02:43 PM
Bfail's Avatar
Bfail
Even with side pipes? Seems like you would at least remove the collectors, so there is some wiggle room with the headers.
Old Oct 12, 2014 | 04:51 PM
leadfoot4's Avatar
leadfoot4
Worst case, you might have to loosen the bolts that secure the side tubes to the car. The gaskets are only 0.050-0.060" thick, so you don't have to move the headers back all that far.
To Under the valve cover
