Erratic Temperature when Heat is Running
Old Oct 6, 2014 | 12:08 AM
AndrewSaran's Avatar
AndrewSaran
2nd Gear
Default Erratic Temperature when Heat is Running
My 81 is experiencing erratic temperature spikes when I turn the heat on. The temp jumps back and forth from 200 to the redline at 260. The car just went through a engine rebuild and the cooling system was refilled. The thermostat and heater core are new. Any ideas on what would cause this erratic temperature issue?
Old Oct 6, 2014 | 12:09 AM
76CSRvette's Avatar
76CSRvette
Did you fill radiator with heater running
