I read a 1.6A drain on my battery until I pull my CLK LTR CTSY fuse. My lights will go off after about 30 secs but the drain is still there. Is it possible for the courtesy delay relay to drain the battery even though the lights go off?
PS Its not the alarm because my alarm horn works.
Should I just get the new Willcox delay board to fix?
Thanks,
Lance
YES...the timer controller can shut off the lights but STILL be energized...and drain power.
Buy one from Willcox...or it can be by-passed if you do not care about the delay option.
