throw out bearing orientation
Before anyone criticizes, Yes 153 flywheels can be found on big blocks and 168 on small blocks. Just speaking in general terms.
Are you wanting to make this "right" or just getting it back on the road?
And here's a pic of the truck bell, car bearing retainer, and spacer.
Re read my last post and tell me what you want to do.....
My guess, your car came with a 168 tooth flywheel and 11" clutch originally and a 621 bell.
Along the way, the flywheel was swapped out with a 153 tooth and a 10.4 clutch. How the truck bellhousing got on there, I have no idea. But that's probably the cause of your trans issues.
So you have a mess of mismatched parts. Asking me for another mismatched part wont help.
What do you want to do?
[/QUOTE]
Gary, this evening I counted 168 teeth on the flywheel. After taking a bit more care to measure the diameter, it stretches to 14". The transmission functions flawlessly, at least for nearly three years. It is the whine, that to the best of my ability, is traceable to the throwout bearing.
I'm not sure why your pressure plate overlaps or if that's an issue. The clutch in my pic is for a 69 corvette with 14" flywheel. Mine is a Sachs k5552-03, bought at Oreileys.
You still have a MAJOR issue with the bellhousing if you're using a trans with the small auto bearing retainer and the truck bell with larger cutout. The trans is centered on the bell by the bearing retainer in the bell cutout. It should be within 0.010 of center. The bolts just hold it.
Take a measurement of the trans retainer diameter and bell cutout. Auto retainer: 4.683 and truck bell cutout 5.124. If yours has these dimensions and no spacer ring (in above pic), you'll have trans problems. That's probably the cause of your whine (pilot bearing, trans input shaft bearing, or gear misalignment).
But with 621 bellhousings under $200, I've never seen a reason to use the truck bell. Although with the Chinese repos for $160 on ebay, expect to need offset pins to center it. At least the I bought was 0.020" off.
[/URL]Purchased from CF member 1960fi, a.k.a. George.
Was the old trans wobbling around in the big truck bell bearing retainer cutout?
Btw, did you figure what your pressure plate/clutch were for? Did their part numbers come back for an 11" vette or 12" truck?
