Cold air intake on my LS1 equipped '82=easy!
#101
Kanvasman-"DOes it appear that you're getting enough air over the dip in the support with the seals in place. Nice work and an inspiration. Thanks."
Yes, I'm retuning it right now because I put a stroker short block in over the winter and it appears not to be running out of air.
Mysticpete- "My engine is very close to the rad. as you can see from the photo, so it will not be exactly the same but the principal is sound. obviously this will be a MAFless tune"
It does appear to be closer to the radiator than mine, so you may have to ditch the MAF, you may still want to consider modifying the top of your radiator support though, every bit of air coming over the top will help.
Metalhead140- "I'm just curious too, why you all run the maf sensor? First upgrade everyone does here in Australia with the LS engines (very common in our Holden Commodores) is fit an exhaust, over the radiator intake, and ditch the maf and get a mafless tune? Is there an advantage to keeping it?"
I used the MAF on mine because there was room for it and I've understood that it compensates for temperature and other variables. I'm sure a good speed density tune will work fine though.
The following 2 users liked this post by Illegal Vette:
Metalhead140 (04-12-2016),
mysticpete (04-12-2016)
#102
#103
mysticpete (05-15-2016)
#106
You also run into the question of what do you do for an air filter and what do you do in the rain and..........
It'd rather spend a little more effort to keep the car's gorgeous lines intact.
To each his own but some things just aren't meant to be seen IMO.
Just sayin'
#107
Originally Posted by Illegal Vette
That's a pretty great idea you had there, I hope you don't mind if I try it with mine! I'm thinking of building a box similar to yours, but with a panel type or flat air filter, a card type MAF and it would draw air from over the radiator support and seal to the bottom to the hood the same as yours. I've just been looking at the space available and it looks doable to me. I'm glad you guys talked me out of the fender vent idea!
#108
Here's are updated pics of the finished airbox installed:
Originally Posted by Danny.reamer
I think it would work great if u did it this was and then added a scoop like this
#109
Following on from Illegal Vettes posting I ended up going the fibreglass route, I must say it was really exciting as I had never worked with fibreglass before. Here's a few photos of my efforts...
I made a mold using perspex, cut and hot glued, I liked this idea as I was able to see how well it would fit below and above.
I used Aluminum right angle to make the seat for the filter, also acted as strengtheners
I then had to alter the design to fit in with a custom radiator shroud, also decided to double the strengh by adding more layers of glassfibre.
I'm pretty pleased with my first attempt at using this material and with a bit of care could have made an even better job of it, but I'm happy with the outcome for now.
#112
Looks good! Let us know how it works out (air temps, power, etc).
I am happy with my DIY CAI also inspired by illegal's post here, really lowered air inlet temps in southern CA - great power and have driven several hundred miles since completed.
