Surprise under the distributor cap.....
Old Oct 16, 2014 | 08:48 PM
Tumblershawn's Avatar
Tumblershawn
Default Surprise under the distributor cap.....
This wasn't what I was expecting to see..... Can someone clarify for
Me. Is this an HEI dist? GM original or aftermarket?
It has electric tach input.
I was expecting to see those little crab claw weights and springs....
Old Oct 16, 2014 | 08:57 PM
MrJlr's Avatar
MrJlr
Looks like HEI to me
Old Oct 16, 2014 | 09:52 PM
Brcmpbl's Avatar
Brcmpbl
You don't say what year your car is, but 1975+ came with HEI. Points before that standard. Picture looks like an HEI.
Old Oct 16, 2014 | 09:54 PM
Shark Racer's Avatar
Shark Racer
That's the rotor. The weights are underneath it. KEEP GOING.
Old Oct 16, 2014 | 10:11 PM
Tumblershawn
Ahh okey doke. I'm pretty new to this (can you tell?), so I'm going VERY slowly. I have about 17 marks on the distributor cap, base, rotor, vacuum canister, firewall, block, etc. etc. and roughly 47 pictures so I can get it back in to where it came from. I'm only changing intake and carb, plugs, wires, exhaust mani gaskets, fluids, etc., so I don't want to pull apart anything I don't have to. If that's a normal HEI, good enough for me. Car is a 73 w 454, but block is a 1970 CE, heads are cast in 72 and numbered correctly for a 73. The HEI was an upgrade of course (I learned that here, not implying that I know what I'm talking about) and other than the fact that it doesn't like spark plugs gapped higher than 0.035" it seems to be performing fine.
Thanks for input and help, Im sure more questions are to follow!
S
Old Oct 17, 2014 | 12:47 PM
80-Vette's Avatar
80-Vette
It not only looks like an HEI it is an HEI.
Old Oct 17, 2014 | 01:49 PM
chevygod's Avatar
chevygod
based on the thread title I was expecting a spider or some such.
Old Oct 17, 2014 | 03:31 PM
dochorsepower's Avatar
dochorsepower
Change that cheap cheap rotor and lubricate the advance weights while you have it off. Also check the advance weights for elongated pivot holes, replace if needed.
Old Oct 22, 2014 | 11:12 PM
Tumblershawn
Ugh I hate spiders!
Can you suggest a quality replacement rotor? Maybe a rebuild kit assuming I will have to replace weights as well?
Thank you!
S
Old Oct 23, 2014 | 05:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Tumblershawn
Ugh I hate spiders!
Thank you!
S
Tumbler-
Why are you replacing the weights?
You might want to read up on this before you tear into the distributor with aftermarket parts. It's an excellent read and you'll learn tons of good info. TIMING AND VACUUM ADVANCE 101 by John Hinckley
Old Oct 24, 2014 | 12:29 AM
Tumblershawn
Thanks, that was informative! So only change the weights if the holes are elongated as per suggestion above? Too bad, my katest order left Wilcox today I think, I should have added a new rotor???
To Surprise under the distributor cap.....
