A/C Removal on a 80', electrical question
I tried a few searches but couldn't find an answer. I removed all of the plumbing and A/C parts from my 80' but what needs to be removed or changed on the electrical side? Obviously the A/C had wiring to make it work an probably has wires coming from the A/C to other parts of the car that may effect the way other things works (idle solenoid on the carb for A/C?)
I'm going to use the heater and defrost so the HVAC controls will still be used and I'd prefer to stick with the stock heater control valve which means in the summer I will set the HVAC control to Max A/C so the heater doesn't get coolant in it.
With that being said what should I do with the old A/C wiring?
Thanks,
Sam
A lot depends if your removed it off the firewall. It held your blower motor...and also other parts that make the speeds of your blower motor effective.
DUB
Good question. Yes I have removed the evaporator case from the firewall and it will be replaced with an AC Delete cover so I can still run a heating core and blower fan. So anything that deals with the heating system and fan are staying. As I mentioned I plan to reuse the vacuum heater control valve system as long as everything works correctly. I plan to test it tomorrow.
Thanks,
Sam
Thanks,
Sam
The problem(s) are going to be getting your blower fan to work on different speeds....because in the factory evaporator case holds the electrical part that allows this....and it needs to have air blowing on it to keep it from failing due to getting too hot. On cars with NO a/c...this part is made into the heater box on the inside of the car if my memory serves me correctly.
Not knowing what the delete cover looks like...it is hard to say any more.
DUB
This is the cover I went with.
http://acdelete.com/pages/68-82_Y-Body.htm
DUB
Also the solenoid for increasing the idle when the A/C is on is up to you and how you car to get that wire out or not.
For what it is worth...I myself would try to hide the wiring if at all possible so the next person who owns it might want to go back with the A/C. I know a new harness can be obtained. The reason I wrote this..I 'put things back to factory' numerous times...and in some cases the wiring or what-have you was not removed...which makes it a snap. Other times...it has been totally butchered..and is a really big pain in my backside to get correct again. I know it is your car and do as you wish (obviously)...just thought I would shed some light from another perspective.....for what ever that is worth.
DUB
I don't want to remove any of the wiring, I'm just wondering if anything needs to be terminated with a load to appease other systems. Meaning, if I remove the A/C and leave the old connectors open, will this impact any other system in the car? I know the A/C max setting shuts off the heater core valve and that when the A/C is on the solenoid on the carb makes an adjustment, but is there anything else I need to be mindful of and connect to something else?
DUB
You do not need to re-wire anything.
DUB
