Can someone post some good pics of how all of the seals are supposed to go around the upper control arms? I don't see any pics in the ASM and im not really seeing how it is supposed to work. Sadly, the kit did not come with any instructions either. I have two large flap type things that obviously mount to the inner fender with push pins, but part of it is just kind of flapping around. There are also two weather strip looking pieces that say for upper control arms, but I have no idea where they go? Thanks.
Hi,
The control arm flaps and apron to frame seals are shown in the AIM in UPC11, Sheet A7, Fender Skirt Seals.
On some cars the apron to frame seal are foam rubber and on others they are a piece of flat rubber of the type the flaps are made from.
Regards,
Alan
A-Arm seal.
Flat rubber apron to frame seal stapled to apron with 3 staples. If the car had the foam seals they are stapled in place too.
