68 turn signals don't work
The flashers work all the way around and I have checked fuses put in new flasher and now have turn signal sw9irch where I can test it .I have 12 volts at the two pink wires at the flasher .When i went to remove turn signal switch there was two very small plastic tapered washers laying in the housing ?? and a flat small metal strip about a quarter inch by one inch long laying in the housing .Both green indicator arrows on spedo gauge light up when flashers work.
Any help would be greatly appreciated.Wes
https://www.google.com/search?q=imag...iw=959&bih=488
For the info
Wes
