REAR Suspension
Old Oct 28, 2014 | 01:36 PM
Kryptonite's Avatar
Kryptonite
Default REAR Suspension
Something feels really loose or just kinda squishy in 1st and 2nd when I ease off. something maybe came loose? I looked under the car everything seems to be intact. Any suggestions. 72 coupe 383 4-speed its the red car
Old Oct 28, 2014 | 02:30 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Only in 1st or 2nd? Odd that it isn't even more pronounced in higher gears, which has me thinking more of a torque related issue. Not easy to pinpoint from internet distance, but with no apparent worn/loose suspension link likely at fault (you may want to do a more thorough investigation than the M1 eyeball test) the next suspects I'd be checking would probably be the diff x-member mounts and diff side yoke endplay. HTH
Old Oct 28, 2014 | 02:48 PM
briankeery's Avatar
briankeery
Snubber bushing?
Old Oct 28, 2014 | 02:56 PM
Kryptonite's Avatar
Kryptonite
Default Snubber
I checked it appears ok but I need to raise the back of the car. Can I do that with a block of wood between the jack and the end of the spring, high enough for jack stand?
Old Oct 28, 2014 | 11:36 PM
Solid LT1's Avatar
Solid LT1
Did you run the car with the rear wheels off the ground at full droop? You probably popped a side yoke snap ring off inside the differential.....grab a wheel and try pulling it in/out a good differential will only move around 1/16-1/8" sloppy one a little more....if the clip is out....it will move a bunch.....not good!
Old Oct 29, 2014 | 11:01 AM
hugie82's Avatar
hugie82
Engine mount might be going...
Old Oct 29, 2014 | 11:13 AM
thegazman's Avatar
thegazman
Default thgazman
Jack up your car at the frame location recommended by GM.
To REAR Suspension
