1981 Manifold vacuum sensor confusion
Old Oct 28, 2014 | 01:48 PM
Moser28's Avatar
Moser28
Default 1981 Manifold vacuum sensor confusion
1981 stock motor, no emissions, no a/c, completely functional CCC system. Here is my issue. I have swapped out the manifold pressure sensor. The new sensor makes the engine ping under load even when I adjust the base timing. BUT I have always had an issue of the trans going into lockup way too early. With the new sensor it shifts perfectly. When I put the old sensor back in the ping is gone and I go into lockup way too early again. I do have the scan tool for this car and both sensors show the same readings. Does anyone have any insight as to whether this is related or am I missing something with the trans or vacuum lines? I hope this makes sense.
