Window Tint
Old Aug 1, 2002 | 05:12 PM
LBL C6's Avatar
LBL C6
Default Window Tint
What is the best method of removing after market window tint. Previous owner had windows tinted and they are too dark for me. I like to see other driver's faces when stopped at lights and stop signs so I can read what they are gonna or not gonna do. This has saved my bacon many times during my motorcycle riding years. I want the other driver too have the same advantage with me when I'm driving the Corvette. Any suggestions? Thanks :eek:
Old Aug 1, 2002 | 05:24 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Window Tint (Terry McIntyre)
Razor blade, it takes forever but it's the only way. Watch out with the back window and the defroster (if you have it). You can scrape the conductive material right off.
Old Aug 1, 2002 | 05:53 PM
Darkness's Avatar
Darkness
Default Re: Window Tint (burners)
I heard that with a hair drier it should come right off. It probably softens it and then it's easier to take off.
Old Aug 1, 2002 | 06:30 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Window Tint (inferno-vette)
Alcohol. spray it, soak it... pull on it... repeat... scrape the remaining glue off with a blade... it will take a little while, but it will come off! :cheers:
Old Aug 1, 2002 | 08:44 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
if alcohol doesn't work try a tiny bit of acetone (nial polish remover) and see how that works
Old Aug 1, 2002 | 10:36 PM
Chris O''s Avatar
Chris O'
alcohol, acetone or fuel will do the trick. Do a search as there was a thread on this a month or so ago.
:cheers:
Old Aug 3, 2002 | 01:35 AM
tangee-vette's Avatar
tangee-vette
Keep the tint........Just curious, do you drive at night when faces are hidden by darkness? :jester :jester :)
Old Aug 3, 2002 | 03:06 AM
Sting Raycin's Avatar
Sting Raycin
Default Re: Window Tint (Chris O')
Use a razor blade and mix up some diluted ammonia in a spray bottle. I don't remember exactly how strong I mixed it, but it took it right off on a truck I did. I wouldn't recommend using any sort of fuel for obvious reasons.
Old Aug 3, 2002 | 03:42 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Window Tint (jdharkey)
GOTO the store and get 2 things...
Some double ought steel wool...
And plenty of elbow grease...
The steel wool works real good with soapy water to get the glue off after you scrape/peel the tint off...
The elbow grease is self explainatory... :D
Old Aug 3, 2002 | 07:27 PM
LBL C6's Avatar
LBL C6
Thanks for all the input. Nope, don't drive at night in Tennessee. Black car, too many deer that think they have the right of way no matter what the out come might be. :seeya
To Window Tint
