Timing off
Old Nov 2, 2014 | 08:43 PM
ftf396's Avatar
ftf396
Default Timing off
Having trouble cranking my engine. It did have a big backfire though the mufflers prior to the trouble. When it does crank it is real rough and will spit through carb. I checked rotor point to #1 cylinder alignment the on compression stroke and it pointed to # 2 cylinder. What could be the problem and how can I correct it?
thanks for any info.
Old Nov 2, 2014 | 09:35 PM
LT-1 kid's Avatar
LT-1 kid
it sounds like your firering order is not correct, maybe a bad timing chain
