Torq Thrust lug nuts and wheel studs
Old Nov 2, 2014 | 10:49 PM
GTOMike06's Avatar
GTOMike06
Default Torq Thrust lug nuts and wheel studs
I bought a set of torq thrusts to replace the spoke wheels on my 68 and ive been having to do the normal emergency brake cable and bracket relocate to make the 18x9s with 5" bs fit. As far as I know the wheel studs are the original. they are 7/16 and I measured em and theyre about 2 inches from end to end. Im using a set of regular acorn lugs nuts since discount tire forgot to order some closed lug nuts. When I put the wheels and lug nuts on it looks like the stud isn't long enough. I measured the stud from the rotor and theres 1" sticking out before I put the wheel on. with them on the front ive got a little over a half inch of threads holding the wheel on and on the back its 5/8" of threads. This doesn't seem like enough to hold the wheels on a 500hp car should I change out my wheel studs? I don't wanna put everything back together just yet and have to pull it all back off to change out the wheel studs.
