Tranny Removal
Old Nov 5, 2014 | 11:55 AM
Wig's Avatar
Wig
Default Tranny Removal
1970 454 4-spd
I have read to remove the transmission, the engine has to be lowered enough to allow the trans to come out. Does the motor mounts have to be loosened to do this? I have the trans completely disconnected and my engine is being supported at the oil pan by a stand and block of wood. I have also unbolted the bell housing. Car is on a mid-rise lift. I have a new Steeroids steering rack installed. Looks like there is not much space to allow the engine to be lowered. Maybe I'm just paranoid!!! Any suggestions? Seems like I am right there, but just not over the hump.
Old Nov 5, 2014 | 12:02 PM
Revi's Avatar
Revi
You need to remove the shifter assy and rods. This will give you enough room to pull the trasmission back and rotate it 90* degrees to get the input shaft past the bell housing. When I did mine I left the bell housing attached to the engine until I got the tranny out.
Also, I had a small jack under the oil pan to raise or lower the engine as needed. I disconnected the tach cable at the distributor, removed the ignition shielding box, and removed the fan so it wouldn't hit the radiator shroud whiile being lowered. I did not loosen the motor mounts. The rear of the engine only needed to be tipped up or down an inch or so.
Old Nov 5, 2014 | 12:38 PM
Wig's Avatar
Wig
Thanks. Yes, everything is disconnected and I have the shield removed and the distributor cap off. Thanks again.
Old Nov 5, 2014 | 12:42 PM
jnb5101's Avatar
jnb5101
I remove the two long bolts that connect the mount to the frame. If the engine is tilted, a lot of torque is applied to the frame extensions.
Old Nov 5, 2014 | 04:37 PM
Wig's Avatar
Wig
Thanks for the response. I'll ponder over either doing it or not.
Old Nov 5, 2014 | 05:20 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Tranny
If the back of the engine won't come down enough, you may have to remove your exhaust from both sides of the engine. Jerry
Old Nov 5, 2014 | 05:38 PM
Revi's Avatar
Revi
When you say disconnected do you mean actually removed from the car?
Old Nov 6, 2014 | 01:04 PM
Wig's Avatar
Wig
When I said disconnected, I mean that there is nothing attached to the transmission. I have it completely separated from the car where I can move it around. Turning it on its side...etc. I have the exhaust off. All I have to do is just take it out. The only thing I have not done is lower the engine. I guess I will try that this weekend. The question I previously asked was should the motor mounts be loosened in order to tilt engine down?
Old Nov 6, 2014 | 01:22 PM
LB66383's Avatar
LB66383
I have never loosened the motor mounts. Just lower the jack that is holding up the back of the engine. That should give you just enough clearance for the input shaft of the tranny to clear the face of the bellhousing.
Old Nov 6, 2014 | 02:07 PM
F22's Avatar
F22
I've got to ask, did you completely disconnect the transmission from the bell housing? You're stating that nothing is attached to the transmission, but does that include the bellhousing? Because I found it to be nearly impossible, without disconnecting it from the bellhousing. If you have, then ignore this, just making sure.
PS, it's still a very tough wrestling match getting it out, that's for sure!!! WWF has nothing on us.
Old Dec 30, 2014 | 04:31 PM
ace_cobra's Avatar
ace_cobra
The manual says to remove the exhaust pipes as well. Is this a necessary step?
Old Dec 30, 2014 | 06:50 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
No. You don't have to lower it enough to require that. It only needs to come down an inch or so. Make sure you block it.
You said you had the exhaust off. If you have the pipes removed from the transmission area, you're good to go.
Old Dec 30, 2014 | 08:37 PM
Hammerhead Fred's Avatar
Hammerhead Fred
No need to loosen the motor mounts - the distributor will hit the firewall long before the motor mounts bind. Be careful not to let the distributor bind too hard against the firewall. You "should" be able to twist the transmission 90 degrees and have the input shaft clear the bell housing and drop forward after that. I have one 4sp where it doesn't clear the bell housing and I'm always forced to disconnect the bell housing and pull it out/down with the front of the transmission. Coming out not to bad - going back in like that takes extra set of hands.
Old Dec 30, 2014 | 08:42 PM
Tbone4432's Avatar
Tbone4432
see my pics. I dropped tranny and you can see I pulled motor with bell housing. I don't know I'd this helps or not.
Old Dec 31, 2014 | 10:15 AM
ace_cobra's Avatar
ace_cobra
I am going to be removing my trans in a few days. I am having a tough time removing the pipes, do they need to come out, or can it be done with them still installed
Old Dec 31, 2014 | 10:23 AM
Revi's Avatar
Revi
Removing the pipes (all of them) from the exhaust manifold to the mufflers gives you much more room to work.
Old Dec 31, 2014 | 10:28 AM
ace_cobra's Avatar
ace_cobra
Any tricks to get the joints apart? I will need to do this to remove the exhaust from the crossmember
Old Dec 31, 2014 | 11:09 AM
Revi's Avatar
Revi
Leave the front pipes bolted to the exhaust manifolds. Unbolt the rear pipes and mufflers. Have someone lay under the car and hold the front pipe just forward of the crossmember, you grab hold of the muffler/rear pipe and move it up/down, left/right, until you make enough play in it to pull it off. Pretty much caveman technology at its best. Then remove the front pipes.
Before it all goes back together, buy an exhaust pipe expander to get the pipes round again and they will slip into place.
http://www.harborfreight.com/large-t...9549-8955.html
To Tranny Removal
