tach
Old Nov 7, 2014 | 09:48 PM
rol51's Avatar
rol51
Default tach
if i elminate the old style points distributor from a 74 that has the tach cable attached to it, and update to a pointless dist. where do i attach the cable to? does this mean my tach wont work?
Old Nov 7, 2014 | 10:06 PM
'75's Avatar
'75
That's correct, you would have to change to an electric tach such as 75 to 77, or get a aftermarket tach drive HEI distributor.
Old Nov 7, 2014 | 10:49 PM
rol51's Avatar
rol51
how do i go from gear driven to electric?
Old Nov 8, 2014 | 04:01 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Crane and Pertronics make a conversion for your OEM distributor to convert from points to an electronic pick up. Then replace the coil and you are ready to go. T
Old Nov 8, 2014 | 09:46 PM
TX-Techman's Avatar
TX-Techman
I had the tach in my 69 converted to electronic. Works great and no more worries with the tach drive distributor.
Old Nov 8, 2014 | 10:13 PM
rol51's Avatar
rol51
can you provide details?
Old Nov 9, 2014 | 01:29 AM
TX-Techman's Avatar
TX-Techman
PM sent,
Old Nov 9, 2014 | 09:53 AM
'75's Avatar
'75
The easiest way is get a tach from a 75 -77 and replace the original, bolts right in. I believe some have used their original face plate to keep it matching. I have a spare from a 75.
Old Nov 9, 2014 | 04:34 PM
TX-Techman's Avatar
TX-Techman
I am not sure what a tach for a 75 or above cost, but bare in mind it will still be a 40ish year old tach. For around $225 you can get a new movement retrofitted into you original gauge, calibrated, and ready to go. I also converted to LED lamps when I put the dash back together, since this is not something I care to take apart again anytime soon.
To tach
